Built H22 running STOCK MUFFLER?????????
Old Jan 11, 2006 | 02:35 AM
crackerjackjokers's Avatar
Default Built H22 running STOCK MUFFLER?????????
I have a fully built H22A vtec motor, here are the goodies:
Skunk2 cams
Skunk2 gears
Skunk2 Valvetrain
JDM Pistons
Ported and Polished Intake Manifold
Full MSD Ignition
AEM Fuel Rail
AEM Fuel Regulator
440cc Injectors
Quaiffe LSD Tranny Custom built
Intake, Headers, 2.5 inch piping to a high flow cat to a STOCK PRELUDE MUFFLER!!!
Heres my question, how much HP gains or power gains am I looking at if I switch to a straight through performance muffler? I feel like the car is choking at high rpm's and it feels restricted
Old Jan 11, 2006 | 07:57 AM
The Weather Man's Avatar
JDM Pistons????????
...............are you running the type-s pistons, or the 10.6:1 pistons?.......
What stage cams are you running..........
what Headers are you running?..........
Also - from the cat to the muffler, is that all stock piping also?...........
Old Jan 11, 2006 | 09:08 AM
BlueLude94's Avatar
Default Re: (TheKINGPin)
Don't you mean Header? Inline four=only one header
I'm sure Yourgetting back up high end, hard to say how much.
What kind of numbers are you making?
Old Jan 11, 2006 | 09:51 AM
Eddiebx's Avatar
i've dynoed a similar motor to yours, with an rsx-s muffler on vs. no muffler, same 2.5" catback piping.
there was up to a 10hp loss from about 5k and up.
and your motor seems to be a stock motor with some cams and springs, how is it "fully built"
Old Jan 11, 2006 | 10:03 AM
bad-monkey's Avatar
Default Re: (Eddiebx)
yup i'd say anywhere from 5-10hp up top.
i dyno'd with a stock cat and a less than free flowing muffler, tuner said it was costing me about 10-12 hp.
PrecisionH23a's Avatar
Believe it or not, the RSX-S mufflers flow VERY well. Doug from hondata actually compared this muffler to a few others and I believe it may have put out 1whp less than 2 of the other 'brand name' mufflers.
Old Jan 11, 2006 | 11:36 AM
mgags7's Avatar
Default Re: (BlueLude94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueLude94 &raquo;</TD></TR><TR><TD CLASS="quote">Don't you mean Header? Inline four=only one header
What kind of numbers are you making?</TD></TR></TABLE>
i have said it before and said it again, stop trying to sound like you know something
the gases flow out of the head, the pipe that connects the head to the exhaust is a header, there are as many of these pipes as there are cylinders, hence the term headers
to the poster: whether you have a built motor or not, the stock muffler is restrictive and putting on a straight through or higher flowing one will pick up horse, regardless of mods
crackerjackjokers
Jan 11, 2006 04:17 AM
ohiohonda
Jul 28, 2005 07:31 AM
GreenTeaLS
May 31, 2005 09:03 PM
Consistent1
Mar 3, 2005 09:43 AM
CivicRaping
Jan 25, 2005 10:22 PM
