d16z6 and d16a6 same bottom blocks?
Old Jan 10, 2006 | 11:17 PM
yz125rider21's Avatar
Default d16z6 and d16a6 same bottom blocks?
wondering if they are the same blocks or not...with no internals and is a d16a6 crank interchangable with the d16z6 block...reason i ask cause I have a d16z6 spare block bare and gonna build it up so i dont have to rush with things...
Old Jan 11, 2006 | 12:13 AM
R_type's Avatar
Default Re: d16z6 and d16a6 same bottom blocks? (yz125rider21)
umm i think that they are pretty much the same except for the a6 block has oil squitters and it has a different comp ratio, and the fan sensor thingy is on the back of the a6 block and the z6 has it on the thermo. housing... o yeah one says "d16z6" on it and one says "d16a6" on it haha...
Old Jan 11, 2006 | 02:35 AM
h8tred's Avatar
From: Commonwealth my ass This is the communist state, VA, USA
Default Re: d16z6 and d16a6 same bottom blocks? (R_type)
I'm pretty sure the A6 doesn't have oil squirters.
Old Jan 11, 2006 | 02:57 AM
jisu009's Avatar
Default Re: d16z6 and d16a6 same bottom blocks? (h8tred)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h8tred &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure the A6 doesn't have oil squirters.</TD></TR></TABLE>
yes that is correct.
I am not sure if they are exactly the same, but I don't think they are.
Old Jan 11, 2006 | 07:57 AM
Khmi's Avatar
I think the z6 uses dished pistons, while the a6 pistions are flat.
Old Jan 11, 2006 | 09:39 AM
spun Vtec's Avatar
Default Re: d16z6 and d16a6 same bottom blocks? (Khmi)
the blocks are basicly the same the a6 girtle is a cast iorn/aluminum unit wile the z6 is a solid aluminum.
cranks are interchangable
compression ratio has nothing to do with the block only the pistons. the piston-deck height on a6, z6, y8 is the same.
the a6 has a little plug thingy that needs taken out if a vtec head is going on top of it. im not sure if it can be put in the z6 block if an a6head is being used. you might want to look into it if you are going to use an a6 head.
there are not oil squirters on any D-series.
hatche1
Apr 21, 2011 11:08 PM
dr_latino999
Jan 29, 2007 08:45 PM
95BG33PGSR
Nov 10, 2006 09:17 AM
fms1day
Northern California (Sales)
Sep 1, 2006 11:03 AM
KStuned
Sep 4, 2003 02:10 PM
