Question about Re010 and RA1
Old Mar 20, 2002 | 01:16 PM
Nuts's Avatar
Default Question about Re010 and RA1
I did a search but come up with different answers.
Are RE010s symmetrical (can you take the tires off the wheels and rotate from left to right?). what about Toyo RA1?
Thanks.
Old Mar 20, 2002 | 01:19 PM
Big Phat R's Avatar
Default Re: Question about Re010 and RA1 (CS)
RA1's are directional for sure- I took off the Re-010s sooo long ago I can't remember - but me thinks they are directional too.
Old Mar 20, 2002 | 01:23 PM
Warren's Avatar
Wrong-Way Wang
I ran my RA-1's forwards, backwards, and flipped on the rim.
Warren
Old Mar 20, 2002 | 01:24 PM
PiYoImuT's Avatar
Default Re: Question about Re010 and RA1 (Warren)
Both Directional.. but don't take my word for it..
hehehehe
Old Mar 20, 2002 | 01:28 PM
rainman's Avatar
Both tires are uni-directional BUT that only matters in the rain - you can do whatever you want in the dry. Also, I really wouldn't recommend running RA-1s on the street unless you've a large bank account. Additionally the RE010's are a great street tire but can chunk pretty badly on the track.
Old Mar 20, 2002 | 02:47 PM
primoEF's Avatar
Default Re: Question about Re010 and RA1 (rainman)
All my friends run RA1s on the street last year, now they all change to T1S or 712, hahaha, I just take their old RA1s for the tracks, How much are they in the states, not that expensive here in Toronto, al least cheaper than T1S, I ran T1S at the track couple times last year and they are sh*t
Old Mar 20, 2002 | 02:51 PM
nsxtcjr's Avatar
New User
The RE010 is symmetrical in the stock 195/55-15 size. As others noted, it's also directional (with a direction of rotation arrow on the tire). If you flip the tire and remount it, you can use it on the other side of the car.
The RE010 also comes in various other sizes (205/50-15, 225/50-16, 215/45-16, 245/40-17) that are designed to be used on the NSX only. In those sizes, the RE010 is asymmetrical (IOW not symmetrical; it has a side facing outwards indicated on the tire) as well as directional, so it should not be flipped and used on the other side of the car. In those sizes, you must order a "left tire" or a "right tire".
[Modified by nsxtcjr, 5:53 PM 3/20/2002]
Old Mar 20, 2002 | 03:26 PM
Nuts's Avatar
Default Re: Question about Re010 and RA1 (nsxtcjr)
great info!! thanks everyone
Old Mar 20, 2002 | 03:27 PM
Nuts's Avatar
great info!! thanks everyone so based on what Warren, RA1 is also symmetrical, is that right?
thanks.
Old Mar 21, 2002 | 07:52 AM
dimsum's Avatar
Yes, Toyo RA1's are symmetrical, so you can remount them if you'd like.
The grooves on any tire are only there to help with wet surfaces. Therefore, if you're driving on dry pavement, it doesn't matter which way they rotate.
Old Mar 21, 2002 | 09:11 AM
HumanResource's Avatar
An NSX chewed up our T1-S's NEW after 3600 miles!!!
Old Mar 21, 2002 | 02:36 PM
nsxtcjr's Avatar
New User
Default Re: Question about Re010 and RA1 (Chris90STD)
What do you mean, "chewed up"?
3600 miles is the normal life of a rear tire on an aggressively-driven NSX. I've gotten as few as 2900 miles on mine.
rmcdaniels
76
Jul 29, 2005 05:48 AM
ITACivic
Jun 16, 2005 02:51 PM
hYbRid_Eg6
Jun 14, 2005 09:01 PM
Ryan126
Apr 12, 2004 09:28 AM
Nuts
Jun 20, 2002 11:49 AM
