wierd sound when i disengage the clutch.. [ video ]
Old Jan 10, 2006 | 09:42 PM
JamesV's Avatar
Default wierd sound when i disengage the clutch.. [ video ]
hey this sound is bugging me.. i dont know if its normal.. im guessing the clutch is messed up but it doesnt slip or anything.. someone help
Heres a video of the sound.. you can tell because it goes .. grrwrwrwrrwrr
the sound only happends when i clutch out.. once the clutch is pushed it goes away..
:: LINK ::
http://media.putfile.com/Movie922727
Old Jan 10, 2006 | 09:45 PM
lv6l's Avatar
anything wrong with your tranny that you know of?
Old Jan 10, 2006 | 09:48 PM
7808's Avatar
Default Re: wierd sound when i disengage the clutch.. [ video ] (JamesV)
could be all kinds a sht probly, sounds like somthing isint disengaging /engaging all the way
Old Jan 10, 2006 | 09:51 PM
JamesV's Avatar
Default Re: wierd sound when i disengage the clutch.. [ video ] (7808)
tranny shifts fine.. its just very wierd. the last owner said it was like that when he bought it.. i dont plan on swapping the engine in awhile just bugs the hell out of me
Old Jan 10, 2006 | 10:09 PM
lv6l's Avatar
well in the video i can barley hear the noise, so i'm not even sure if i herd the right noise. but when you let go of the clutch pedal the noise gets louder or softer?
Old Jan 10, 2006 | 10:43 PM
JamesV's Avatar
louder
Old Jan 10, 2006 | 10:52 PM
lv6l's Avatar
give me some infos on yoru car. model year. original motor? new or old clutch? milage on cars etc.
Old Jan 10, 2006 | 10:57 PM
komat's Avatar
Default Re: (lv6l)
its your input shaft bearing on the tranny
https://honda-tech.com/zerothread?id=596873
replaced it on my b16 tranny
took me about a day to do it
wasnt hard
Old Jan 10, 2006 | 11:01 PM
Cory Matthews's Avatar
Default Re: (lv6l)
that sounds is comming from your clutch. so imma guess its clutch chatter.
it can either be a
loose flywheel
clutch not disengaging all the way
or really a fucked up bearing.
i cant think of anything else becase your motor is fine and your tranny is fine so it must be somewhere in the middle.
Old Jan 10, 2006 | 11:08 PM
4dohs4mohoes's Avatar
Default Re: (Danger Hart)
I dont have the badwith to listen to it (56k), But I'm going to take a guess that its the release bearing. I've replaced many of these due to the same sound your hearing. It takes about 3 or 4 hours to relace depending on the tools and experience you have. The bearing costs like 40 bucks from Honda.
Old Jan 10, 2006 | 11:10 PM
JamesV's Avatar
so.. i should change the whole clutch
its a stock 93 cx with a d15b7 motor probably stock clutch too
Old Jan 10, 2006 | 11:11 PM
UNKNOWN_MEMBER's Avatar
Default Re: (boo bees)
lol does it like growl when you drive? if so, mine does the same thing. Too much torque from the single cam so it just ***** the tranny up
Old Jan 10, 2006 | 11:19 PM
komat's Avatar
Default Re: (UNKNOWN_MEMBER)
just buy another cx tranny
they cost like 30-50
Old Jan 10, 2006 | 11:29 PM
JamesV's Avatar
Default Re: (komat)
i dont know.. br1anpham saw my motor and said its not the motor thats suppose to be in the cx.. i dont know what tranny it has.. how can i identify its a cx tranny?
Old Jan 10, 2006 | 11:37 PM
Default Re: (JamesV)
Who cares what kind of tranny it is. Any D-series tranny will bolt up. But the problem is; even if you buy a whole new tranny, the release bearing could still be bad. Don't buy a new trans. just replace the release and pilot bearing. That should fix all!
Dont think too much into the problem and replace things that dont need replacing. That's the biggest problem people have. Just figure out the main problem and fix it. If it consists of the tranny being replaced, then replace it. But don't go to extremes.
Old Jan 11, 2006 | 12:17 AM
JamesV's Avatar
k cool.. thanks..
ill go do what you said.. hopefully thats the problem then ill work on the next step:-p
EG_SINZ
Transmission & Drivetrain
Mar 6, 2016 11:38 AM
Chaser4dr
37
Jul 25, 2007 11:59 AM
RefuseRice
Oct 19, 2004 10:16 PM
2000gsrsedan
Aug 26, 2003 12:05 PM
garados
Dec 20, 2002 03:17 PM
