TIRES
Old Jan 10, 2006 | 07:16 PM
Kapetan's Avatar
Default TIRES
I have a 95 SI VTEC, and I want to know what possible tire sizes I can use with my stock rims, stock tires are 14 inch, all suggestions are appreciated.
Old Jan 10, 2006 | 07:44 PM
EG2Driver's Avatar
Default Re: TIRES (SugaDaddy)
You could go slightly wider, but common sense tells me you cant put 15 in tires on 14 in rims.
Old Jan 10, 2006 | 08:15 PM
Kapetan's Avatar
How slightly... in 200's maybe??? like 215, cause now I have 185...
Old Jan 10, 2006 | 09:05 PM
Integra_drk's Avatar
Default Re: (SugaDaddy)
id go 195 at the most. Definately not 215. You might be able to pull 205 if your a daredevil, not sure if thats been done.
Old Jan 10, 2006 | 09:07 PM
x93coupex's Avatar
Default Re: (Integra_drk)
^^^what he said 195 is what i would go
Old Jan 10, 2006 | 09:49 PM
RTI's Avatar
RTI
Default Re: (x93coupex)
195 is as wide as I would go on the 5 inch steelies. 195/60R14 is what I run.
Old Jan 11, 2006 | 06:04 AM
alwaysoverkill's Avatar
most tires for 205 want min 5.5" wide rim. i'm running 205/50/15 on 15" steelies 5.5" wide and its the min, but also there is alot of tire flex too, wish I went with 195/50/15 but i'm upgrading the rims to 7" wide instead.
if you look on the tire manufacturers site, they list min and max rim width needed, and what they recommend.
195 is all i'd go to on 14"
Old Jan 11, 2006 | 06:08 AM
Slow EJ8's Avatar
Default Re: (alwaysoverkill)
Focus you attentions on getting a better tires compound rather than increasing the diameter of your tires. I would take a better tire compound in 185 over some crappy POS in 215 diameter. So basically focus on what tire you want with the desired level of 'stick' and then worry about size.
old man neri's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra_drk &raquo;</TD></TR><TR><TD CLASS="quote"> You might be able to pull 205 if your a daredevil, not sure if thats been done. </TD></TR></TABLE>
I have 205s on my 13s..........not sure why.
If I were you I would just stick with that was is stock, if you do go wider make sure you get the appropriate profile ratio to make sure your speedo/odometer stay accurate.
Old Jan 11, 2006 | 07:01 AM
Kapetan's Avatar
Im buying Pirelli's, so I want to know if they make 195's in 14 inch... thanks for your input everybody... u have been helpful..
thank you
Old Jan 11, 2006 | 07:17 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SugaDaddy &raquo;</TD></TR><TR><TD CLASS="quote">Im buying Pirelli's, so I want to know if they make 195's in 14 inch... thanks for your input everybody... u have been helpful..
thank you</TD></TR></TABLE>
Pirelli makes the P6 all season and the P6000 all season in the 195/60R14 size. This size is the closest to your 185/60R14 stock size. It is 2.1% bigger or 0.5" bigger diameter than stock. There are much better tires out there than Pirellis. Try the wheel and tire forum for help in your decision.
Cheers.
http://www.tirerack.com/tires/...8&y=8
Old Jan 11, 2006 | 07:27 AM
Kapetan's Avatar
Thanks for the site...
I know there are better, like yoko, kumho, michelin, but I am looking to see if I can get Pirelli's, what do you run on ur car, if u dont mind me asking
Old Jan 11, 2006 | 07:31 AM
Slow EJ8's Avatar
When talking about tires there is not always one certain brand that is better than another. For example, comparing Perelli's to Yoko's wont get you very far but comparing specific tires from each manufacturer will be more beneficial.
Perhaps you could list what you are looking to get out of a tire and we could list some specific suggestions. Here is a few things to get you started.
-will these need to be used in snow/icey/frigid cold?
-how long do you expect/want them to last?
-will they see any track time?
-what is your approximate budget?
Hopefully that will get you started.
Old Jan 11, 2006 | 07:36 AM
Kapetan's Avatar
I am buying two separate sets, one set for winter, one set for summer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SugaDaddy &raquo;</TD></TR><TR><TD CLASS="quote">what do you run on ur car, if u dont mind me asking </TD></TR></TABLE>
Oh course I don't mind! I run Sumitomo 200s. They have been descibed as mediocre at best. However they are 13". I run these because I have almost no choice when it comes to summer 13" and they were like $35 a piece. As a student this is a very nice feature. Also I don't race at all so I have no need for a super duper tire. Just something that works somewhat in the rain and warm weather.
It's all about what your needs are and what your budget is.
EK k kay
Jan 20, 2005 03:05 PM
M-Type
Apr 1, 2003 10:32 AM
gsrpilot8000
Sep 16, 2002 02:09 PM
SIK IN DA HED
Jul 29, 2002 02:13 PM
4doorRS5spd
Feb 5, 2002 06:19 PM
