Best D series tranny?
Old Jan 10, 2006 | 06:27 PM
SovXietday's Avatar
Default Best D series tranny?
My tranny is getting old, I can feel the bearings starting to go bad and am just waiting for my synchros to start going bad too. I have an EJ8, I'm not much of a transmittion guru, all I know is that it's the stock 97 EX transmission.
Is a hydro tranny better than a cable tranny? If so, do they even make a good hydro tranny for a Dseries? Or should I just buy all new bearings and synchro's and just rebuild my stock one?
Thanks.
Old Jan 10, 2006 | 06:41 PM
haveaniceday's Avatar
Default Re: Best D series tranny? (SovXietday)
you now have the best d16 tranny .. either find one with lesser miles or rebuild yours
Old Jan 10, 2006 | 06:45 PM
Civicse's Avatar
i say if you have the time and money, rebuild yours.
Old Jan 10, 2006 | 06:57 PM
prada_G's Avatar
Default Re: Best D series tranny? (Civicse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haveaniceday &raquo;</TD></TR><TR><TD CLASS="quote">you now have the best d16 tranny .. either find one with lesser miles or rebuild yours</TD></TR></TABLE>
Old Jan 10, 2006 | 07:04 PM
SovXietday's Avatar
Default Re: Best D series tranny? (prada_G)
Thanks guys. I'll just rebuild when I have a free weekend.
Old Jan 10, 2006 | 07:06 PM
97spooncivic's Avatar
or i will trade you my dx tranny which is better for your crappy old ex tranny which isnt worth my .02 cents
Old Jan 10, 2006 | 08:32 PM
d16vtecx's Avatar
92 and up civics all have hydro trannies and you can't use a cable tranny
Old Jan 10, 2006 | 09:52 PM
lv6l's Avatar
is his 97 ex tranny same or different from a 92-95 ex/si tranny
Old Jan 10, 2006 | 09:56 PM
SOHC4life 96's Avatar
Default Re: (lv6l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l &raquo;</TD></TR><TR><TD CLASS="quote">is his 97 ex tranny same or different from a 92-95 ex/si tranny</TD></TR></TABLE>
Slightly different. The gear ratios are nearly exactly the same. The only major difference is the shift forks. 92-95 trannies have aluminum shift forks, 96-00 trannies have steel.
Old Jan 10, 2006 | 10:07 PM
lv6l's Avatar
oh i see. is aluminum betteer than steel? also i herd a guy told me that del sol tranny are good. i thought the gear ratio were the same as the 92-95 ex/si so what is really the truth?
Old Jan 10, 2006 | 10:10 PM
Default Re: (lv6l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l &raquo;</TD></TR><TR><TD CLASS="quote">oh i see. is aluminum betteer than steel? also i herd a guy told me that del sol tranny are good. i thought the gear ratio were the same as the 92-95 ex/si so what is really the truth?</TD></TR></TABLE>
Steel &gt; aluminum The del sol's had the same engine/tranny combo's as the civics
The gear ratios are different but so closely different it's not even noticable.
Old Jan 10, 2006 | 10:20 PM
siregcivic's Avatar
Default Re: (SOHC4life 96)
i personnally believe the best d series tranny would have to be the d15b.. if u can find the one with lsd.. i think that would be the one to get no???
Old Jan 10, 2006 | 10:27 PM
Default Re: (siregcivic)
i think its better just becasue it has the lsd
Old Jan 10, 2006 | 10:30 PM
siregcivic's Avatar
Default Re: (97spooncivic)
ya.. i heard that it also has the same gear ratios as the 92-95 si hatchie.. with the .750 5th gear instead of the 92-00 ex.. .702 5th... and ofcourse who could not love lsd???
Old Jan 10, 2006 | 10:44 PM
These are all true statements, but if you ever plan on adding large amounts of hp to your engine then the LSD will crap out on you. I think it's only good up to 170ish hp.
Old Jan 10, 2006 | 11:29 PM
lifeofbean's Avatar
mmmm LSD... oh wait.. limited slip, not acid.. *cough*
96-00 EX tranny would be your best bet, 92-95 EX/Si being the second. Like everyone said, same gear ratios, the 96+ is just a little tougher (and easier to find with low miles).
Avoid anything besides the EX tranny unless you want tall gears.
Old Jan 10, 2006 | 11:51 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: (lifeofbean)
If you have a LOT of free time, there IS a D-series that came with a optional LSD, tho I think it was a cable, so you'd have to convert it to hydro. Feel free to hunt one down.
Old Jan 11, 2006 | 01:06 AM
siregcivic's Avatar
Default Re: (Redline96LX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline96LX &raquo;</TD></TR><TR><TD CLASS="quote">If you have a LOT of free time, there IS a D-series that came with a optional LSD, tho I think it was a cable, so you'd have to convert it to hydro. Feel free to hunt one down.</TD></TR></TABLE>
actually you are correct... twin can zc cable tranny had optional lsd.. my friend had one.. it was bitchen.. also it had closer ratios.. hed walk all over me in my 94 dx coupe ex motor si tranny like nothing... 4 car lengths in the quarter he topped out at 125 tho.. id own him on the freeway
there is 2 d series trannys that came optional lsd.. only from japan tho.. (im pretty shure about that one) i didnt ever see any d trannys in us that are lsd yet soo correct me if im wrong...
i know the obd0 twin cam zc had optional lsd zc tranny cable and
d15b vtec had optional lsd hydro .
thats the only ones i know about tho
civic_in_LA
13
Jan 5, 2006 06:57 PM
teefunk01
Oct 25, 2005 05:24 PM
dustrag
Jan 27, 2004 12:11 PM
92KillerBee
Sep 21, 2003 08:27 AM
