tdc on d16a6 crank?
Hey my dsl is down and I am on dial up and I only need to see a pic of where tdc on crank is at...is it the mark on crank all by itself?...or is it the middle mark of the three...I cant member...reason I am asking cause I am having some major hesitation off the line and bad backfire....if I can get what mark is what and what you guys think the problem is that would be nice...sorry I cant search at this moment, you all know how slow dial up is.....thanks in advance
From: I told you to wait in the truck in Texas, United States
The one all by itself is TDC..
The one in the middle of three is for setting ignition timing
with a timing light.. >b16 but close enough..
TDC on the crank is the single mark off by itself to the right of the 3 ignition timing marks - should be white - did you just change timing belt or mess with cam setting?
