95 accord ?
Old Jan 10, 2006 | 05:05 PM
Slow_import's Avatar
Default 95 accord ?
hi my g/f has a 95 accord and when it hits a little bump in the road theres a clonking sound comming from the front two wheels....had a mechanic check it an said it could be the shocks or tie rod ends....
Well i already ordered new shocks but just thought before i change them out i'd see if any of you guys have this same problem....maybe you guys could tell me so while i have everything off i could change them if it was the problem....
all advice is appreciated...
Old Jan 10, 2006 | 05:10 PM
lobudgetr's Avatar
My 95 accord does the same thing, it needs struts, and an alignment. I would say yours probably would need the same thing
Old Jan 10, 2006 | 05:21 PM
hondadude's Avatar
Default Re: 95 accord ? (Slow_import)
The tie rod ends can make a nice clunk when going over bumps; to check them raise the car and grab the tire at 3&9 'o' clock position, then wiggle the tire and feel for bumping, you might get some one to look under and check for movement on the outer and inner ball joint; while the tire is in the air, take a prybar and check the lower ball joint for movement by prying between the ball joint and lower control arm
Just because someone else needs struts doesn't mean all accords need them replaced
Old Jan 10, 2006 | 07:01 PM
bluskye's Avatar
Default Re: 95 accord ? (hondadude)
Tack on Upper or Lower ball joints as well on the check list of "clunkable" items.
Old Jan 10, 2006 | 07:07 PM
oukewldave's Avatar
i just had the exact problem. i just replaced the swaybar bushings 4 days ago and problem was gone. id check that first see if the rubber is falling apart
Old Jan 10, 2006 | 07:11 PM
bluskye's Avatar
Default Re: 95 accord ? (oukewldave)
You might as well check every piece of rubber on the front suspension including the struts and strut mounts to sum it all up.
Old Jan 11, 2006 | 08:12 PM
yea i have the struts ordered....i just got my alignment done to with a 3 year warranty....so i dont think its that but i'll check the sway bar bushings too....is it hard to replace tie rod ends and the sway bar bushings....
Old Jan 12, 2006 | 05:35 AM
Honda-Master's Avatar
any of the suggestions given to you could cause a noise, ,, but if i were you i would not buy or replace anything untill you properly diagnose what it is,, it might only be 1 of these 4 - 5 suggestions,, and i would not install the new struts till you know for sure ,, cause you will be upset if after replacing them the noise will still be there............
Old Jan 19, 2006 | 12:25 AM
Jay84ever's Avatar
They're struts not shocks. Yea, mine does that too all 4 of them. How much was is for the struts? Check all the front bushing too!
zorobabel
Jul 22, 2017 02:04 PM
dtran002
Mar 1, 2011 11:23 PM
civicdelsol33
Nov 21, 2008 12:41 AM
89turboteg
Feb 22, 2007 08:55 AM
