vss code??
Old Jan 10, 2006 | 04:35 PM
MattsHatch93's Avatar
Default vss code??
Just curious i got a vss code on my 88 crx, well at least thats what the faq says....I didn't think that my car would throw a code for that since it is a cable operated speedo? is there wires that go from the cluster to the computer for the vss??? i'm just curious.... The speedo cable broke when i put the new motor in it so i can see why it would be throwing a code if there is a connection between the cluster and computer.....
Old Jan 10, 2006 | 04:56 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: vss code?? (MattsHatch93)
Inside the speedometer is a sensor that triggers a pulse
to the ecu..
So yes,if the cable is unhooked,It will throw code 17..
Old Jan 10, 2006 | 06:15 PM
Default Re: vss code?? (88DXCRX)
you sir are my hero for the day
Old Jan 10, 2006 | 06:23 PM
88DXCRX's Avatar
The sensor and connections on the cluster:
How to re-connect cable at transmission:
https://honda-tech.com/zerothread?id=1325930
beatngyou27
26
Nov 8, 2013 06:59 AM
EF9 JAMS!!!
Dec 10, 2006 10:26 AM
HT Chaplain
Oct 25, 2006 08:26 PM
Joebroni
May 29, 2005 12:43 PM
