drag kit installation
ok, this is my first turbo installation and ran into a problem. I've been basicly going by this guide step by step.
https://honda-tech.com/zerothread?id=635014
we are having trouble finding where to tap in for my oil feed line. from what ive seen this guide doesnt explain where to tap it. Any verbal help or by photographs is apressiated. thanks
On a b series if you reach down on the back of the right side of the block under the intake manifold you will feel where the oem oil light switch is and that is where it goes .It is by the oil filter . I have no idea where the d series is?
From: On a island w/ only a bridge to leave it, U.S.A
Its right above the oil filter, at least is was on my D engine. take off the wire on top, remove the OEM with a 19 or 20mm wrench put on your brass fitting there is a vacuum hose you might hae to take off it got in my way, make sure you put it back on right ofter so you dont forget. connect the brass fitting make sure to use silicone tape, then reattactch your new fitting into the block, just as it shows in the picture. and you all set
thanks for the information guys. Also i am having trouble getting to all of the body clips to take the front end off. Any advice or an easy way to get them off? Should i attack them from the engine bay or the wheel well. I just cant seem to get to them
thanks
thanks
EG-SIXV-TEC
May 23, 2012 07:05 AM
brasilianstreet
Jul 2, 2005 03:40 PM
