FS: 99-00 Civic Si prop. valve, DX calipers, 13/16" master cylinder, Drum Spindles, UCAs & more
Legend Rear Calipers - e-brake eliminator $45
These are the rear calipers from a Acura legend. Will fit over the "large" rear brake pads of Hondas, such as the ITR, Accord V6, 97-01 Prelude, Legend, TL, CL, CR-V, Pilot, etc. These are the kind with the big *** rear piston, and bolt on like stock, but they eliminate the e-brake attachment, using a regular piston with no rotating crap. Ideal for racing.
Civic 13/16" Master Cylinder - $15
In fantastic condition, no problems. Bolts onto 98-01 Integra Brake boosters, 96-00 Civic brake boosters. Retails for $134 new, this is in perfect running condition.
Honda CRV Front Licence Plate holder - $15 shipped
This is the front licence plate bracket for an 05-06 Honda CRV. Includes the metal bracket, plastic inserts, two screws, and metal bracket clip; everything you need to bolt on the front licence plate holder. Necessary if you live in a state that requires a front licence plate.
ABS wheel sensor - $10
Came from a 95 Integra GS front knuckle. Will work on Civics and Integras, and probably many more Hondas with ABS. THis is the pickup sensor which is screwed to the knuckle near the axle to read ABS. Good replacement if yours broke. I have not tested this to verify functionality. Retails at $85 new.
Integra DC2 Front Right Spindle - Pending
Integra Front knuckle from a 95 Integra GSR. Comes with bearing, hub, and dust shield in good condition. Good replacement if your bearing took a **** or you broke some lug nuts. Retails new for $189 for the bare knuckle. Sorry the dust shield is slightly bent at the bottom, but its thin metal and you can rebend it by hand.
Civic/Integra 4-lug front hubs (2) - $15
These are the hubs with lug studs in them from a 99 Civic Si. Will fit the bearings of any 88-00 Civic or 90-01 Integra and some other Hondas. 4x100 lug pattern. Lugs are not bent or stripped. Hubs are not bent or broken. Hub pair retails for $226 new plus $8 for the lug studs.
D16Y7 Intake manifold - http://cgi.ebay.com/ebaymotors...59982
in like new condition, clean, no scratches on face, vacuum line attachment tubes are perfect. Retails for $232 new.
96-98 Sedan 4 door taillights - $40
OEM, Great condition, i kept them waxed all the time. No scratches or nicks, seals are even in great shape. Retail for 150$ new
OEM civic steering wheel, 96-00. - $30 O.B.O.
Good shape, no rips or bends or tears. Light Grey. Retails for $81 new.
Honda Clutch Master Cylinder Resovoir - 10$
This is from a 97 Integra Type-R. Will fit all 94-01 Integras (manual transmission) and I believe most Civics from 88-00. Some dirt in it, but cap is in great shape, and so is the resovoir, no nicks or bending or breakage.
96-00 Civic Coupe/Sedan Stock Rear speakers - B.O.
These are the stock 6x9" rear speakers. In almost perfect shape, no scratches
at all or bends.
88-00 Civic/90-01 Rear trailing arm and Drum Spindle - 50$ (pickup prefered)
This is the rear drum brake setup on the trailing arm from a 96 civic. Same drums as any 88-00 Civic (except CRX HF - I can't confirm but I believe it had smaller drums). Will go onto an Integra as well, like if your track racing (for the less weight.) Bushing on the control arms are in fantastic shape, about 3 months and 5,000 miles on them. Entire setup is in good condition. Pickup prefered in the Atlanta area because shipping will be about $50. Bearings are good, and new rear hubs alone retail for $180.
1995 Integra GSR UCAs - $20
1995 Integra GSR Compensator arms - $10. Retail for $68 new.
These are the Rear Upper control arms, Rear compensator arms, and rear trailing arm to a 95 Integra GSR. Will fit all 94-01 Integras and 92-95 civics and Del Sols (since they have all the same suspension.) In great shape, the bushings are all good. come with bolts if you want them. I also have a rear stock rubber brake line from a 95 GSR in good condition like if you ripped one of yours.
__________________________________________________ ___
Civic Si EM1 99-00 4040 Prop. Valve - SOLD!
The Civic Si proportioning valve. A must have for anyone with a EK thats converting to rear discs. This bolts onto any 96-00 Civic, and is needed for swapping rear drums to discs to balance out the brake bias. Retails for $80 at dealers.
ITR Calipers with 23T brackets - SOLD
These are the Calipers for an Integra Type-R. Bolt onto Integras, Legends, and with the 3mm wheel spacer will allow your Civic or non-R Integra to take the front 11.1" brakes. These are the big calipers with the big pads.
Civic Front Calipers - SOLD
For the 9.5" rotor front brakes, will fit on almost all Honda knuckles, calipers were meant for the 9.5" rotors on non EX/Si civics from 88-00. Good upgrade for the CRX HF, good shape replacement if your calipers broke. Seals are great, come with brackets. From a 96 Civic LX, will go on DX, LX, CX, EX (no ABS 92-95) knuckles on 88-00 Civics. Retails for about $200 new, these are in working condition, seals are still fantastic.
Modified by Redline96LX at 2:45 PM 2/13/2006
Modified by Redline96LX at 1:26 AM 2/15/2006
at all or bends.
The part numbers on the 96-00 Civic CX hatchback are exactly the same as the 99-00 Si, why is that?
Its for the 96-99 Civic DX and CX hatch is the same as the 99-00 Si. I'm not sure, but seeing them in person, the letter on the prop. valve is not the same, tho the part numbers listed on hondapartssource.com seem to the same. I'm not sure why, possibly because the hatch is so light that they didn't mind the front brake bias on it. I'm still trying to find out why, but i know that the parts in person at least, are not 100% the same, cause the letters on the front arent the same.
bump. I'm back bitches! If you IMd me in the last week, please IM me again, sorry about the trouble.
Modified by Redline96LX at 8:24 PM 1/30/2006
