code 67 Catalyst low efficiency? what does it mean?
it means your cat isn't working right and your secondary o2 sensor is not seeing enough of a difference in readings from what the primary o2 sensor is saying. typically happens if you gut your cat, or replace it with a testpipe. you can get an o2 simulator or CEL fix to override it.
its most likely because i have my 2nd o2 sensor taped to the primary wire so since it takes 3 time to trip the code i could just reset my ecu? how much and where can i get an o2 sim and how does it work?
drinksprite
Sep 14, 2018 12:00 PM
Bossup!
Sep 9, 2009 07:35 PM
EG2 SiR
Mar 4, 2004 10:35 AM
