t3/t67 opinions needed..
A friend of mine is selling me a almost brand new t3/t67 turbo for 600 bucks..I'm currently ls/vtec turbo with a precision sc61..I made 312whp on 12psi using uberdata which i found to be a bit low but all the parts i have done to my motor..I am going to retune again hopefully in march with hondata and am hoping to hit mid 400's on 20psi..would it be better to stay with my sc61 or buy the t67? any comments welcomed..
what are the specs on the sc61 that you've got now?
If you don't mind a little more lag then the t3t67 will definitely put you over the 450hp mark
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andysila »</TD></TR><TR><TD CLASS="quote">how used is it? why is he selling it?</TD></TR></TABLE>
He tuned his car and is building another setup..has less than 1k miles on it..no shaft play.
i have an sc61 on my setup now and i made 600hp with it at 28.5lbs.i going to change to the t3/t67 ho for this season.i wouldnt change unless your just going for pumpgas #s.i made like 420hp on 18lbs on 94pump with the sc61.
