B18B swap in 89 hatch
Old Jan 10, 2006 | 12:30 PM
2ndGenIntegra's Avatar
Default B18B swap in 89 hatch
hey im doin a swap into my hatch and need some help. i cant get the axles into the hubs. so would it be better to use the DA hubs. my friend said i could also buy new axles. what should i do?? thanks for you help
Old Jan 10, 2006 | 12:33 PM
jlicrx's Avatar
Default Re: B18B swap in 89 hatch (2ndGenIntegra)
is your hatch the STD model (4 speed, etc.)? if so, you need 88-91 CRX/Civic DX or Si knuckles/hubs - you could use the DA also
Old Jan 10, 2006 | 12:35 PM
Mach69's Avatar
You are going to need to tell us which hatch you have, that would really help. More than likely jlicrx is right, he is very informative, he has helped me many times.
Old Jan 11, 2006 | 06:53 AM
i think my hatch was is the std one. so should i just switch the hubs wit my DA hubs.. do you think that would save me more time and money?? thanks..
Old Jan 11, 2006 | 09:28 AM
civickiller's Avatar
Default Re: (2ndGenIntegra)
if you have the da hubs laying around and dont need them for your integra, then yeah switching them would save you time and money. but remember if you upgrade to da brakes you need to run bigger rims than the stock 13"s because they wont clear da brakes.
Old Jan 11, 2006 | 10:37 AM
tangerinebeast's Avatar
do the axles splines look larger than the splines in the hubs liek the diameter could be the hub messd up or something because my friends were really hard to get in on one side
Old Jan 11, 2006 | 11:56 AM
The splines on the hubs look way smaller than the ones on the axles.
Old Jan 11, 2006 | 01:22 PM
Jonathan_ED3's Avatar
Sounds like you've got an STD.
Swap out those Integra hubs!
Old Jan 12, 2006 | 11:48 AM
My friend said if i swap all of the integra brakes over, i will have to change the brake booster or something. he said the civic brake booster wont have enough power to stop the integra brakes... is that true?
Old Jan 12, 2006 | 11:57 AM
no, the civic booster will be just fine.
Put in a master cylinder from an EX and you'll be golden.
Old Jan 12, 2006 | 12:51 PM
i have another question.. can i just switch the whole DA brakes with the A arms and everything?? do u think it'll work??
FernEF
Oct 18, 2006 05:42 AM
ProjectJDMIntegra
Oct 10, 2005 03:04 PM
93CharcoalHatch
Aug 3, 2005 08:31 PM
nomotor
Mar 22, 2005 05:28 PM
