dsm 450 cc injectors
http://cgi.ebay.com/ebaymotors...wItem
will these work
i saw these on ebay and they say they will work on civic/tegs i wanted to know if they plug right in or do you have to do any modification they come with fuel ump rail and regulater im looking into running a turbo at the end of this month running 7-8 lbs
i have a d16z6 w/
act stage 2 clutch
act 12 lb flywheel
full msd ignition
apexi vafc
thermal cat back
will these work
i have a d16z6 w/
act stage 2 clutch
act 12 lb flywheel
full msd ignition
apexi vafc
thermal cat back
just get some blue top injectors they will work perfect just dont put them in tell you turbo or you will run into some problems at low rpm's
Im using those 450 cc black top 2nd gen DSM injectors in my setup... They work GREAT... They have a dual spray pattern to for better fuel atomization than the blue tops. You cant use the fuel rail...just use yours. If you need help, Ive got pics of how i put mine in, just had to space the fuel rail mounting studs out a bit. I am not that far from you and will help you out if need be. Im running 10psi on a f22b1.
My vote, yes use them...but make sure to clean them first. I used my buddys ultrasonic cleaner with injector cleaning fluid in it.
Car runs great...I got them from that same guy!
Hope that helps...
Spiker
Hope that helps...
Spiker
hysteria411
Engine Management and Tuning
26
Sep 30, 2013 06:12 PM
slotec
May 26, 2005 05:39 PM
threatcon13
Jan 31, 2002 08:32 AM
