Eg suspension setup question
Old Jan 10, 2006 | 10:05 AM
Rionmann's Avatar
Default Eg suspension setup question
I just installed some skunk2 coil-overs and KYB AGX shocks. I just wanted to know if my ride should be boucey because the springs are stiff or is just because they we just installed them( i.e. last saturday)?
Old Jan 10, 2006 | 10:09 AM
dohcVTECeg2's Avatar
Default Re: Eg suspension setup question (Rionmann)
give it time to break in
Old Jan 10, 2006 | 10:10 AM
kaiba's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rionmann &raquo;</TD></TR><TR><TD CLASS="quote">I just installed some skunk2 coil-overs and KYB AGX shocks. I just wanted to know if my ride should be boucey because the springs are stiff or is just because they we just installed them( i.e. last saturday)?</TD></TR></TABLE>
Are your shocks adjustable?
Old Jan 10, 2006 | 10:13 AM
Rionmann's Avatar
Default Re: Eg suspension setup question (kaiba)
Yes they are...
Old Jan 10, 2006 | 10:18 AM
Everyones Hero's Avatar
Set them to a stiffer setting. If you have high spring rates they should not be bouncy, they should be stiff.
Did you preload them correctly?
Old Jan 10, 2006 | 10:21 AM
Rionmann's Avatar
Default Re: Eg suspension setup question (Everyones Hero)
Thats is the thing, When I bought the set-up it came pre-assemble. So, all I did was installed drop my car off the lift and left the shop, but if you can explain what you mean by preload I can take off the set-up re-assemble it
Old Jan 10, 2006 | 12:56 PM
Rionmann's Avatar
*bump* cause I really need to know...
Old Jan 10, 2006 | 12:58 PM
lazie's Avatar
make sure that your AGX's arent lowerd past 1.5in there not designed to go that low.
Old Jan 10, 2006 | 12:59 PM
mantic6t9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Everyones Hero &raquo;</TD></TR><TR><TD CLASS="quote">
Did you preload them correctly?</TD></TR></TABLE>
Preload? hahah explain that to me.. I am intriged!
Old Jan 10, 2006 | 01:09 PM
Default Re: Eg suspension setup question (mantic6t9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mantic6t9 &raquo;</TD></TR><TR><TD CLASS="quote">Preload? hahah explain that to me.. I am intriged!</TD></TR></TABLE>
I've never installed them so I don't know how to preload. I thought that it was important to preload coilovers.
civicsareslow
Suspension & Brakes
20
May 17, 2006 07:35 PM
larryd
Aug 16, 2005 06:12 PM
sleepinbeauTEG
Jun 13, 2005 03:25 PM
ham
Feb 3, 2005 08:35 AM
RIX982DRLS
Jan 23, 2004 02:54 PM
