Doing a H22A swap into a 96 Accord and need help!
Old Jan 9, 2006 | 10:36 PM
Joshp14's Avatar
Default Doing a H22A swap into a 96 Accord and need help!
Just signed up to the board tonight and I need help with this...I'm not a Honda guy...I own a 01 WS6 so I'm not a big import guy so dont poke fun at me if I dont use the correct terminology.
I have a co-worker that is paying me to install a JDM H22A into his 96 Accord. Here is a list of things that are already done:
-F22 Pulled
-F22 engine harness moved to H22A engine
-EGR, IAC, and other sensors wires extended to reach.
-Distributor wiring was different on both cars, as the F22 used a CKP sensor down by the crank pulley, whereas the H22A's is in the distribtor....so I ran wiring over to the distributor and got that all wired up.
-Bracket made for throttle cables (F22 bracket mounted farther back than the H22A bracket did)
Here are my problems now:
-Driver side motor mount is different (we have a prelude motor mount on the way)
-We have a OBD2 to OBDI conversion harness from Boomslang, and for the life of me I cant figure out where the long pigtail goes to. It has 3 main sets of connectors....one set plugs into the new H22A ECU, the second set plugs into the ECU connectors that used to plug into the F22 ECU, and then there is about 2 feet of wire going to another set of connectors...but I dont know where these go. Someone said it goes to the tranny control module, but I dont know where that is. I was looking under the passenger side dash and also under the center console and cant find it. All I can find is the airbag module and the ABS module. Which by the way, the connectors fit perfect into the ABS module...
With the one end of the boomslang harness plugged into the new ECU and the other end plugged into the harness connectors on the car (with the long pigtail still disconnected) the car cranks but wont start. We can smell fuel, and we are getting spark...I'm assuming it has something to do with me not being able to find where this other plug goes from this boomslang conversion harness.
Sorry for the long schpeel, but I need some help here!
Old Jan 10, 2006 | 08:48 AM
Joshp14's Avatar
Anyone?
Old Jan 10, 2006 | 07:54 PM
Joshp14's Avatar
ttt...
Old Jan 10, 2006 | 11:31 PM
jdmwestcoaststyle's Avatar
Default Re: (Joshp14)
i am pretty sure the reason no reply is because they all want u to search for it on the thread. there are plenty of threads on here about swaps. specially the h22 into an accord. i would give u all the info but i am no where near as informed as u, plus too lazy too look for it.
Old Jan 11, 2006 | 08:51 AM
Joshp14's Avatar
Thats the problem...I searched and couldnt seem to find the answer. If someone knows the answer why not take 2 sec to reply?
Old Jan 11, 2006 | 09:38 AM
SpeedFreak77's Avatar
Take a pic and post it, may help to identify what your needing help with.
Old Jan 11, 2006 | 07:18 PM
Defiant7m's Avatar
Default Re: Doing a H22A swap into a 96 Accord and need help! (Joshp14)
Hey check your e-mail
Allan
Old Jan 12, 2006 | 04:53 AM
Joshp14's Avatar
Default Re: Doing a H22A swap into a 96 Accord and need help! (Defiant7m)
Thanks a lot!
Old Jan 12, 2006 | 06:34 AM
Defiant7m's Avatar
No problem..
Old Jan 12, 2006 | 09:12 AM
raceACCORDingly's Avatar
this should answer most of your questions...
http://board.hondasociety.com/...61998
ricb20vtec22
Oct 15, 2012 06:53 AM
redbullet_02
Oct 4, 2011 01:19 PM
Auto96accord
Aug 13, 2006 04:40 PM
94 accord h22a
Aug 14, 2005 02:31 PM
