MSD+NGK+BOSH
Old Jan 9, 2006 | 09:12 PM
highriskZc's Avatar
Default MSD+NGK+BOSH
I GOT ZC DOHC AND I JUST GOT MSD IM USEING NGK WEIRS AND BOCH PLUGS SHOULD I GO ALL NGK OR MSD OR SHOULD I USE THE BEST FROM THEM ALL
THX FOR THE HELP
Old Jan 9, 2006 | 09:17 PM
Sleepy_Red_hatch's Avatar
Default Re: MSD+NGK+BOSH (highriskZc)
the caps lock button is between the "TAB" and "^SHIFT" buttons,
you seemed to need help finding it
Old Jan 10, 2006 | 06:48 AM
highriskZc's Avatar
Default Re: MSD+NGK+BOSH (Sleepy_Red_hatch)
how bout this if u dont know and u want to be a dum #$%
ppl get on this site to ask ? if u wnat to be a %^&**keep it to your self
Old Jan 10, 2006 | 07:34 AM
old man neri's Avatar
I would just get NGK plugs, and as for wires, just get what is in your price range. Just get what is the best for each catagory, I don't see a need to go all with the same name brand. Probably all comes from the same factory in China anyways.
(it's BOSCH by the way)
Old Jan 10, 2006 | 07:39 AM
Everyones Hero's Avatar
Default Re: MSD+NGK+BOSH (old man neri)
It's all personal preference.
Some peolple say OEM wires are the best.
By the way, don't be such a ******-assed little bitch when people reply to your threads. It's really not a good way to have someone help you, alright?
Old Jan 10, 2006 | 07:49 AM
JDM-Punk's Avatar
get w/e you think works best
...just a little hint, No matter what you post a topic about someone will flame it( talk **** about you or your post/topic)
Old Jan 10, 2006 | 08:29 AM
HatchNaPlan's Avatar
Default Re: (IknowYou)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IknowYou &raquo;</TD></TR><TR><TD CLASS="quote">
...just a little hint, No matter what you post a topic about someone will flame it( talk **** about you or your post/topic)</TD></TR></TABLE>
Isn't that Honda-Tech in a nutshell???
Old Jan 12, 2006 | 07:01 AM
JDM-Punk's Avatar
Default Re: (HatchNaPlan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchNaPlan &raquo;</TD></TR><TR><TD CLASS="quote">
Isn't that Honda-Tech in a nutshell??? </TD></TR></TABLE>
dont you love honda tech bitches?
Old Jan 12, 2006 | 07:15 AM
mwieczorek43's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchNaPlan &raquo;</TD></TR><TR><TD CLASS="quote">Isn't that Honda-Tech in a nutshell???</TD></TR></TABLE>
Honda-tech in a nutshell would be... Don't be an idiot, and you'll do fine.
Don't break the rules, don't ask stupid questions, and don't post stupid commments. If this guy spent any time at all on this site, he'd know what happens when you post in CAPS LOCK: flamage.
To original poster. Generally speaking, most Honda enthusiasts will tell you, stick to NGK plugs and factory wires; unless you are making high hp numbers there's not alot of need for aftermarket plugs (or ignition for that matter). But if I had to suggest wires... i'd say Nology.
Old Jan 18, 2006 | 03:13 PM
ReDHaTcHyGuy's Avatar
all u need is the 2 dollar ngk plugs ... thats what most people use
Old Jan 18, 2006 | 03:19 PM
ABK's Avatar
ABK
Default Re: (ReDHaTcHyGuy)
NGK blues are pretty much OEM, get those MSD wires aren't all that good.
Don't use BOSCH shitty plugs (they only work on european piece of **** cars), use NGKs or denso.
Old Jan 18, 2006 | 03:28 PM
XxRoCkMaNxNEOxX's Avatar
Default Re: (ABK)
get ngk plugs and wires
Old Jan 18, 2006 | 04:02 PM
EG2Driver's Avatar
Default Re: (XxRoCkMaNxNEOxX)
I WOULD SAY NGK BECAUSE THEY WORK BETTER THAN THE BOSCH EVER DID ON MY CAR. And yea, dont write with caps lock on.
Old Jan 18, 2006 | 04:09 PM
Cute EK's Avatar
No questions are stupid( as long as they are in the right forum) unless of course no one answers them. Then it's a waste of time.
Modified by Cute EK at 6:12 PM 1/18/2006
Old Jan 18, 2006 | 04:29 PM
Archidictus's Avatar
Unceasing Measure
Here's the final answer:
For your ignition needs, you'll want to get OEM spec and gapped NGK plugs from Advance Auto/Autozone/NAPA/whatever if not the exact OEM ones from a dealership. For spark plug wires, you want OEM. Period. Yes, they're about as expensive as an aftermarket set of wires, but there's a good reason for that: they're the best you can get.
For a distributor cap and rotor, get whatever you want. I run an MSD cap and it's wonderful, with an OEM rotor. For the ignition coil, I'd stick with either stock or MSD.
Bosch stuff isn't going to kill your car at all, but since OEM is just as expensive, I always go with OEM. Honda makes good ignition components. Stick with them.
Old Jan 18, 2006 | 05:12 PM
Cute EK's Avatar
Default Re: MSD+NGK+BOSH (aallbbeerrtttttt)
Sorry, wont happen again. What would be an example of a stupid question, exactly?
builthatch
22
Aug 9, 2022 05:29 AM
Jamied
11
Mar 2, 2006 04:08 PM
isumase
Apr 28, 2005 04:00 PM
Foxcow
12
Jun 22, 2004 09:23 AM
skrewdlude
Jul 28, 2002 12:04 PM
