help on strut bar on ej8 (searched)
Old Jan 9, 2006 | 08:04 PM
amej8's Avatar
Default help on strut bar on ej8 (searched)
yes i searched and didn't get far due to the billions of posts on strut bars...
the car: 99 ex coupe (ej8 chassis, d16y8 motor)
the budget: ~50ish
was wondering which strut bar (without pivots like the cheap ebay ones) would work on my car. i read somewhere stock gsrs or si's would work? also, can they bolted right up the strut towers or do i have to get holes drilled. i prefer to find one that can be bolted right up the strut towers. also, do the bolts have to be torqued a certain amount?
i will be taking my car to a shop to get the bar installed so id like to get all info i need.
thx h-t
Old Jan 9, 2006 | 08:06 PM
Turbo_y8's Avatar
Default Re: help on strut bar on ej8 (amej8)
taking it to a shop to install a strut bar??
this is as easy as "installing" a shift ****
4 bolts of 4 bolts on!
Old Jan 9, 2006 | 08:11 PM
Turbo_y8's Avatar
Default Re: help on strut bar on ej8 (tuck'd98)
http://www.meganracing.com/upl...S.jpg
Old Jan 9, 2006 | 08:14 PM
amej8's Avatar
like i asked...if they have to be torqued to a certain amount, that'd be a problem. no money for renting tools, etc.
also the problem with jacking up the front end onto jack stands or cyn blocks (which 1. i cant afford the jack stands and 2. dont have anywhere around me for miles to find cyn blocks) so the wheels are off the ground. and since my car is 6 years old, im afraid of either 1. stripping the strut bolts or 2. ending up breaing them from forcing em off. ive already attempted to get em off and ended up just rounding off the bolt head without moving em a millimeter even with grease.
Old Jan 10, 2006 | 11:04 AM
turbob18si's Avatar
I dont wanna sound like Im flaming but this is the easiest mod next to an air freshener. All you need is a ratchet and a 14mm socket. Anyone who wants to work on there car should have some basic tools. Take your $50 dollars down to Sears and pick your self up some tools so you dont waste your money paying people to do the work for you. You will save alot of money over time doing things yourself.
Old Jan 10, 2006 | 11:09 AM
sohcvtec1995's Avatar
Default Re: help on strut bar on ej8 (turbob18si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbob18si &raquo;</TD></TR><TR><TD CLASS="quote">I dont wanna sound like Im flaming but this is the easiest mod next to an air freshener. All you need is a ratchet and a 14mm socket. Anyone who wants to work on there car should have some basic tools. Take your $50 dollars down to Sears and pick your self up some tools so you dont waste your money paying people to do the work for you. You will save alot of money over time doing things yourself. </TD></TR></TABLE>
correct.. you donty need a jack, or any special tools to do a strut bar.. and the strut bolts are usually not rusted or anything since they are high in the engine bay.. and please dont take your car to a shop.. they WILL laugh at you while they take your money for the 15 min install.
Old Jan 10, 2006 | 11:15 AM
Turbo_y8's Avatar
Default Re: help on strut bar on ej8 (sohcvtec1995)
like i said its the easiest install.
i understand you lack the tools and knowledge.
for hondas your only gunna need metric sockets, wrenchs, you can almost completely dissasemble a honda with a 12mm and 14mm sockets and wrench,
buy a socket set, wrenchs, maybe some different size drives, screw driver and youll be set, you can do alot with that, a jack/ramps and slowly youll learn your away around your car.
You gotta start somewhere!
Old Jan 10, 2006 | 11:44 AM
dohcVTECeg2's Avatar
i'll install it for you for 50 bucks
Old Jan 10, 2006 | 12:38 PM
JRizEJ6's Avatar
Default Re: help on strut bar on ej8 (dohcVTECeg2)
$20 at walmart will get you a 115pc. tool set. perfect for your car
Old Jan 10, 2006 | 02:14 PM
amej8's Avatar
okay so now that every1 is telling me i can do it on my own, which bars would work on mine? i dont have the budget to by a neuspeed, dc, etc. will a gsr or si or type r bar work? and i read in a diy i found searching on here somewhere that they have to be torqued to 33 lbs/ft or something? can ij ust hand tighten em with a socket wrench as much as i can?
Old Jan 10, 2006 | 03:02 PM
97spooncivic's Avatar
they all work the same, buy the cheapest one you can find.
mrdeadman
Apr 20, 2006 04:24 PM
shutta
Jan 6, 2006 01:10 PM
vaajboy
Sep 8, 2004 06:58 AM
Bone Stock
May 4, 2004 12:30 AM
revhrdls
Aug 4, 2001 03:51 AM
