sohc question
i got a jdm d15b head and titanium springs and retainers for a d16z6 will the springs work in the d15 and also will the distributor work from the d16 to the d15 thanks
it should all work..the only difference in the the head of the d15 and the z6 is the cam in the d15b has a more aggressive profile. which is why that motor ouyts out more power then the z6. that and the ecu of course.. other then that the head is pretty much the same...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">it should all work..the only difference in the the head of the d15 and the z6 is the cam in the d15b has a more aggressive profile. which is why that motor ouyts out more power then the z6. that and the ecu of course.. other then that the head is pretty much the same...</TD></TR></TABLE>
I think the Dist will work. I have a D15B in my garage and the dist appears to be identical to that on the D16Z6. I could check for numbers/take a picture of them side by side tomorrow if that would be helpful.
B
B
