I have ac but no heater
#1 be sure the heater **** isn't broken
#2 is the **** stiff when it does work?
#3 You should check the heater control valve to be sure it's opening and closing.
Depending on what you find we can go from there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecpower3088 »</TD></TR><TR><TD CLASS="quote">You might need a new heater motor. unfortunatly that will put u back about $800-900. I hope you live somewhere warm.</TD></TR></TABLE>
what are you talking about my man ????
do as Moo suggested,, also chk the t-stat make sure it is not stuck open...when car is warmed up, make sure lower radiator hose is almost as hot as upper hose
check your water valve for proper operation. if it is not open when the heat is on, you get no heat. maybe the valve broke or the cable broke or the motor that moves it on the head unit is had.......
I have had several honda dealers tell me that the valve can break and either stay open or closed even though the lever is moving on the outside of the valve. the only way you are going to know for sure is to take it off and test it.
Craigc187
Aug 31, 2015 12:18 PM
