timing with aftermarket cams: do i do anything different?
Old Jan 9, 2006 | 05:46 PM
hatchinprogress's Avatar
Default timing with aftermarket cams: do i do anything different?
im about ready to do my timing/valves for my dohc zc it's a semi-built motor....and for the head i got performance valves and springs and i got delta regrind cams (260/272)
so do i need to do anything different when i set my timing or make my valve adjustment?
Old Jan 9, 2006 | 07:06 PM
jdmcars.com's Avatar
Default Re: timing with aftermarket cams: do i do anything different? (hatchinprogress)
Depending on the cam, most aftermarket cams require the engine to be Zero'd out and valve clearences checked (this is what a good motor builder/machine shop does).
Old Jan 10, 2006 | 04:25 AM
Default Re: timing with aftermarket cams: do i do anything different? (jdmcars.com)
thanks...so your saying just do a valve job and set the timing..right?
Old Jan 10, 2006 | 04:58 AM
Autoworks's Avatar
I beleive it is zero it out, assemble it all at TDC and set adjust the valves to OE spec, then tune timing from there once its all assembled and clearance is right.
Old Jan 10, 2006 | 12:47 PM
Default Re: timing with aftermarket cams: do i do anything different? (Autoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks &raquo;</TD></TR><TR><TD CLASS="quote">I beleive it is zero it out, assemble it all at TDC and set adjust the valves to OE spec, then tune timing from there once its all assembled and clearance is right.</TD></TR></TABLE>now when you guys say "zero it out" what do you mean??? (set everything @tdc right?)
Old Jan 10, 2006 | 03:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote">now when you guys say "zero it out" what do you mean??? (set everything @tdc right?)</TD></TR></TABLE>????
Old Jan 10, 2006 | 05:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote">now when you guys say "zero it out" what do you mean??? (set everything @tdc right?)</TD></TR></TABLE>bump
Old Jan 10, 2006 | 05:09 PM
jlicrx's Avatar
yes, set crank to TDC and align cam gears
Old Jan 10, 2006 | 05:17 PM
Default Re: timing with aftermarket cams: do i do anything different? (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">yes, set crank to TDC and align cam gears</TD></TR></TABLE> thanks alot once again you come to my rescue
Old Jan 13, 2006 | 04:34 AM
Autoworks's Avatar
yes...
stagen
Dec 21, 2008 07:31 AM
mr_magoo
Aug 23, 2008 12:41 AM
PhoenixDownVII
Nov 24, 2007 10:46 AM
eater_eg6
Oct 9, 2005 10:40 PM
4ornia
Mar 26, 2004 11:14 AM
