2 Different brands of Resin, Are they compatible?
Old Jan 9, 2006 | 05:37 PM
silentblackhat's Avatar
Default 2 Different brands of Resin, Are they compatible?
I have a Cargroom Fiberglass Resin and I have Bondo all purpose fiberglass resin. I am making a subwoofer enclosure and i have the speaker ring mounted allready. I am about to stretch the fleece over the speaker ring and all then fiberglass-resin that tonight. for the first part of the box, i used Cargroom Fiberglass resin and i am wondering for the fleece and the rest of the box if the Bondo All-Purpose fiberglass resin will be compatible with the first part of the box. I checked the data sheet and they both have the same amount of styrene in it (Both specs for both brands say 40%-50% on their chemical composition chart).
Any help would be appreciated.
Old Jan 9, 2006 | 06:10 PM
carbonall's Avatar
* B A N N E D *
Default Re: 2 Different brands of Resin, Are they compatible? (silentblackhat)
I wouldn't mix them but you can use one of them, let it cure then use the other. If they are both polyester resins this should work fine
Old Jan 9, 2006 | 06:57 PM
Default Re: 2 Different brands of Resin, Are they compatible? (carbonall)
alright, yeah i wouldnt mix them or anything. they are both polyester resin. I have half of the box allready made with the Cargroom brand. I bought the bondo brand at home depot so i can finish the projecct tonight. THe part that i have with the cargroom brand is allready cured(sitting for a few days) so all i have to do is stretch the fleece over the rest of the box and put resin on that to finish it(of course ill fiberglass it also).
SO this should work out alright?
Old Jan 9, 2006 | 07:16 PM
carbonall's Avatar
* B A N N E D *
scuff it up a little but it should be fine
Old Jan 9, 2006 | 07:29 PM
Default Re: (carbonall)
alright thanks. i just finished trimming everything and as i went along the edges, i scuffed everything up pretty well.
Old Jan 9, 2006 | 07:44 PM
carbonall's Avatar
* B A N N E D *
sweet well good luck with your project
Old Jan 9, 2006 | 11:33 PM
thanks, ill probably post pics of it all. when its done.
romoracing
Audio / Security / Video
Apr 16, 2006 12:58 PM
initialvtec
19
May 29, 2004 06:51 PM
GoLowDrew
Jul 17, 2001 09:36 PM
