What can take boost alot better?
Old Jan 9, 2006 | 04:24 PM
PphamEK's Avatar
Default What can take boost alot better?
What can take boost better, b16a or b18b. The reason i ask is my friend says that a b16 can run better takein boost better than a b18b. Probly cuz he has a b16 and he talk **** bout the b18b.Which ima gettin
Old Jan 9, 2006 | 04:54 PM
vancoland's Avatar
take boost better?..the hell do you mean? both engines take boost the same. You mean more psi's? B16's will probably take less psi's than the b18b before it will blow because of the higher compression. But the b16 will also make more power or the same power with lower psi's than the amount put into the B18b
Old Jan 9, 2006 | 05:26 PM
haveaniceday's Avatar
Default Re: (vancoland)
to many factors to throw in .. but id like to say the b18 .. lots of ppl are biased.. dont wanna say anything else is better.. id honestly rather have the b18b in my car than the b16.. prolly will turn into a who likes what thread.. get your b18, add a vtec head, and then boost.. and let your car do the talking
Old Jan 9, 2006 | 05:51 PM
Jay_Sensing's Avatar
At lower psi's???????
Comon guys, for the last time, it doesn't work that way, flow rates of the compressor combined with the exhaust housing and ability to flow X lbs per minute determing a lot more thant "psi's".
You can judge off of what wheel horse power an engine will fail at, not what "psi's" it will hold because 8 "psi's" on a T25 will not even approach 8 "psi's" on a T3/60-1.
All in all, it all depends on the tune at what horsepower level an engine will fail at. Just make sure you build the car right and do your research and you will have a good time with it.
Old Jan 9, 2006 | 05:55 PM
xEnderx's Avatar
Default Re: (Jay_Sensing)
Its not about PSI, its about how much air the turbo flows.
Why not at least ATTEMPT to do your own homework? I'm sure you can find plenty of information by using a little skill called "search" and another one called "reading".
thevoice
Apr 5, 2007 06:46 AM
stierhund
Jun 27, 2003 06:49 AM
ej1civic
May 16, 2003 12:36 AM
gtfourmn
Nov 8, 2002 07:42 PM
H22CIVIC
Oct 22, 2001 04:10 AM
