D16Y8 - SOHC Mounts - What are you running? >>
Old Jan 9, 2006 | 12:36 PM
platinum00's Avatar
Default D16Y8 - SOHC Mounts - What are you running? >>
I just want to see what all the SOHC guys are running for mounts. I have the ES inserts for the rear and 2 lower mounts.
im interested in the other 2 mounts. i think one is the tranny mount on the passenger side, and the other i guess is an upper engine mount. It's the mount on the upper driver side right near the cam gear. what are you using for these mounts?
im having serious wheel hop issues, and these 2 mounts look worn. I just ordered a Full-Race traction bar so hopefully that might help as well
platinum.
Modified by platinum00 at 6:11 PM 1/9/2006
Old Jan 9, 2006 | 12:38 PM
igo4bmx's Avatar
ES motor mounts like you
i also have an NRG engine damper (40+ bucks on nopi)
Old Jan 9, 2006 | 12:39 PM
SOHC_MShue's Avatar
Default Re: D16Y8 - SOHC Mounts - What are you running? >> (platinum00)
ES inserts in the torque mounts.
Old Jan 9, 2006 | 12:58 PM
creechrr's Avatar
Running JimFab torque mounts. The interior vibrates like mad but, the engine hardly moves. I think my rear mount is blown.
Old Jan 9, 2006 | 12:59 PM
ELSpool's Avatar
All the ES mounts, no hopping, no tractions bars..yet..
Old Jan 9, 2006 | 01:07 PM
Kelly.'s Avatar
I've quit using this account
sorry, i didnt see this post with replies already, so i replied to the other one
here is what i said:
i run a nrg dampner and all stock mounts.
anytime i launch i preload
i dont have wheel hop problems, i have traction problems
do you preload?
Old Jan 9, 2006 | 01:33 PM
BlackCRX's Avatar
i know this thread is probably regarding ek's but i have a y8 in a crx
upgraded to es motor mounts, still had some wheel hop. went with es strut rod bushings which are basically radius arm bushings, this solved almost all the problems
still get slight hop but its litterally all gone now
Old Jan 9, 2006 | 01:44 PM
platinum00's Avatar
Default Re: (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">ES motor mounts like you
i also have an NRG engine damper (40+ bucks on nopi)</TD></TR></TABLE>
what is an engine damper....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">ES inserts in the torque mounts.</TD></TR></TABLE>
so the other 2 mounts im talking about our called torque mounts? what are the part numbers?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by llewsirc &raquo;</TD></TR><TR><TD CLASS="quote">
do you preload?
can you explain how to do this?
thanks for you help guys
platinum.
Old Jan 9, 2006 | 01:56 PM
platinum00's Avatar
Default Re: (platinum00)
is preloading just putting load on the clutch before droping ?
platinum.
Old Jan 9, 2006 | 01:59 PM
Kelly.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">
it is a "shock" the is supposed to kep the motor from torque'ing back towards the firewall.
i have one and i like it.
once i get back to the dyno, ill do a pull with and without to see exactly how much it helps
but for ~$50 at nopi.com, i figured what the hell
Pre-loading: Hold the e-brake up, let clutch up just enough so you can feel the car pull, while holding the revs at what ever you want to launch at. You drop the cluth and the e-brake at the same time. Off you gooooo!
taken from this thread:
https://honda-tech.com/zerothread?id=770050
While in the pre stage, With the e-brake up (button pushed in/removed) Let the clutch out just enough to where it feels as if the car wants to pull forward. Set your Launch RPM. "Pump" the car forward by letting the E-brake up/down slightly until you're staged. When you feel it's go time let the e-brake down in the same motion the clutch is being released.
https://honda-tech.com/zerothread?id=1382054
there was s good write up on preloading
i searched the drag racing forums but couldnt find it.
might try searching the entire site for preload.
it is basically what is said above.
its easier to go from alittle bit or rpms to alot then from a dead stop to 6k rpms.
hope i helped.
Old Jan 9, 2006 | 02:00 PM
platinum00's Avatar
i found the damper to. so i guess the only unanswered question is about the torque mounts. what are the part numbers for inserts, and are these for the 2 mounts i was talking about.
platinum.
Old Jan 9, 2006 | 02:09 PM
platinum00's Avatar
Default Re: (llewsirc)
llewsirc,
great info man. thank you.
im going to order that NRG damper. is there any difference from that to the ingalls one. just looks like the ingalls is more money.
it would be nice to feel a little power before 3rd gear. i want to take my car back to the dyno to turn the boost up, but there is no reason if i cant get power now.
platinum.
Old Jan 9, 2006 | 02:19 PM
EARLdaSQUIRREL's Avatar
official honda whore
if you already ordered the full-race traction bars i wouldnt really worry about it, from what i recall you can get inserts for the top mounts in an ek and then you'd be set
brian
also it depends alot on your suspension setup
Old Jan 9, 2006 | 02:34 PM
platinum00's Avatar
Default Re: (coptzer)
here is my current suspension setup. let me know what else i can do.
Ground Control custom rates 350f/450r
Koni Yellows Full adjustable. - 1/4 from full in front . 1/2 from full in rear
Omni-Power front and rear camber kits
Suspention Techniques front and rear sway
Neuspeed front upper and rear lower tiebars
16's on Falken Azenis RT-615
Full-Race Traction bar - ON ORDER.
NRG Engine Damper - ON ORDER.
thanks for everyones help.
platinum.
beerbongskickass's Avatar
I bought all 3 lower jimfab motor mounts for $110 shipped and that completely eliminated my wheel hop. My motor is now rock solid.
Old Jan 9, 2006 | 02:36 PM
platinum00's Avatar
Default Re: (beerbongskickass)
if he would responed to my email he would have had another order
how do you get ahold of that guy
platinum.
Old Jan 9, 2006 | 03:08 PM
Kelly.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">here is my current suspension setup. let me know what else i can do.
platinum.</TD></TR></TABLE>
wow.
you should deff learn to preload.
i run skunk2 coilovers, stock (~199k miles) shocks, nrg damper, stock motor mounts.
i preload and can get 2.1 60fts (on BFG DR's)
with alittle more seat time im sure 2.0s are doable.
preload
preload
preload
Old Jan 9, 2006 | 03:27 PM
Drew Peacock's Avatar
How well does the TQ dampener work? Any info? Will it bolt onto a zcsohc or d16a6?
Old Jan 9, 2006 | 03:34 PM
BlackCRX's Avatar
i have never launched with pre-loading
always 2step
i was wondering if someone would be nice enough to maybe post up an example of 60foot different btwn preload and normal launching
Old Jan 9, 2006 | 04:05 PM
Default Re: (BlackCRX)
Pre loading just helps the axels from busting into pieces...
Old Jan 9, 2006 | 04:29 PM
ladysman's Avatar
Default Nopi Link
Can someone post a link on NOPI site where you can get this for $50? I might try one of these dampers for $50.
To me, the traction bars made the biggest difference in the world. Mount helped but not as much as the bars did.
Old Jan 9, 2006 | 04:32 PM
platinum00's Avatar
Default Re: Nopi Link (ladysman)
ebay has the NRG one for $49.00
search for civic damper.
platinum.
Old Jan 9, 2006 | 05:12 PM
Quad-Damage's Avatar
Default Re: Nopi Link (platinum00)
Im runing Hasport Race Mounts
70mm not the full drag mounts, I like it
Old Jan 9, 2006 | 05:20 PM
platinum00's Avatar
I finally found the one on nopi.com
http://www.nopionline.com/nopi...02000
You would think someone as big as nopi would have a better site than this. There website is horible. Anyway total with shipping is $58.79
platinum.
Old Jan 9, 2006 | 07:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">I finally found the one on nopi.com
platinum.
</TD></TR></TABLE> If there any thing like the dampeners used on nissans there not actually a shock at all just a metal rod and some high density plastic. But any reviews?
