new clutch
hey need some questions answered. First off i got up this morning and started my car and when i pushed in my clutch it went to the floor and felt like nothing was there and so i let it out and pushed back in and tried to put it into gear and it wouldn't go so i tired reverse and it just grinded, whats your thoughts? also im thinkin its my clutch i have a 95 civic coupe that i wanna turbo with a t3 and run about 9 psi i have injectors for it and all what kinda clutch would you suggest?
Sounds like theres air in your clutch lines. Look by your pedal is there a pudde of fluid? If so then its you Clutch Master Cylinder.
Check around your slave cylinder and see if theres any oil. Try a regular bleed and see what happens.
If you can't understand that, you're not going to understand how to fix it. Look on your transmission for a little thing bolted to the front of it with a hard line attached to it. Look to see if it looks like fluid is leaking there. Follow that hard line back to your master cylinder and see if you can find fluid leaking there (it will be in your floorboard by the clutch pedal inside your car).
It doesn't sound like your clutch is dead so much as your master/slave cylinder.
check the front of the transmission for a part that looks like this....
this is from a prelude, but very similar...this is called the slave cylinder. If this is leaking at all, all the hydraulic fluid is going to seep out, rendering your clutch pedal useless. Sounds like the culprit to me, but it may be other things as well
Sounds like the slave cylinder is out. It's a $10 replacement from Auto Zone. All you'll need is a 12mm socket/ratchet and a 10mm line wrench. If that doesn't solve the problem, it's your master cylinder. Here's how to replace that: https://honda-tech.com/zerothread?id=1265999
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jowee 1162 »</TD></TR><TR><TD CLASS="quote">Sounds like the slave cylinder is out. It's a $10 replacement from Auto Zone. </TD></TR></TABLE>
Uh, try $50. At least thats how much mine was from advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">
Uh, try $50. At least thats how much mine was from advance.</TD></TR></TABLE>
Uh, try $10 plus tax from AUTO ZONE.
Uh, try $10 plus tax from AUTO ZONE.</TD></TR></TABLE>
I see $30...right in between
http://www.autozone.com/servle...INDER
http://www.partsamerica.com/Pr...set=A
^ From Advance. Ranging from $30-$65. So, I don't know WHERE the hell you got $10 from.
I'm sorry, $11.99
CLUTCH SLAVE CYLINDER for a
1994 HONDA CIVIC SI
Normal Stock
Special Order
Not Available
Item Part
No.
Warranty Core
Value Unit
Price Availability
Store Web
BRAKEWARE 13090 3 MO $11.99
1994 HONDA CIVIC SI
Normal Stock
Special Order
Not Available
Item Part
No.
Warranty Core
Value Unit
Price Availability
Store Web
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jowee 1162 »</TD></TR><TR><TD CLASS="quote">I'm sorry, $11.99
Same part #, 13090 shows $29.99 for my zip code. Oh well, I guess **** is cheaper in TX.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow_redcivic »</TD></TR><TR><TD CLASS="quote">ok and i checked where you put clutch fluid in and its empty think im just out or i have a leak somewhere? </TD></TR></TABLE>
No offense, but I don't think you will be able to fix this...
Check your clutch fluid. Its the smaller resivoir next to the brake booster/master cylinder. Is is low?
Have a friend put his hand on the shift fork... (You can feel it through the big rubber boot at the end of the slave) and push the clutch pedal in and out. Does it move?
If the shift fork/slave isn't moving, or there is no fluid in the clutch fluid resivior, then you have a leak or a bad slave.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow_redcivic »</TD></TR><TR><TD CLASS="quote">i put fluid it and it lasted about a minute and it was on the garage floor</TD></TR></TABLE>
Then try taking the advice of others and fixing the problem.......
