Best place to get a block sleeved?
Old Jan 9, 2006 | 09:19 AM
Rene M's Avatar
Default Best place to get a block sleeved?
I have a spare jdm B18C5 i want to send out to have sleeves installed in but do not know who to trust. Any suggestions?
By the way i want 84mm bore open deck...
Old Jan 9, 2006 | 09:28 AM
Rene M's Avatar
Default Re: Best place to get a block sleeved? (Rene M)
Thanks R.J.......
https://honda-tech.com/zerothread?id=565375
Old Jan 9, 2006 | 09:30 AM
BlueR's Avatar
yup, Earl Laskey/Benson's
bar none
thats where mine just came back from 84mm g00tness:
Old Jan 9, 2006 | 09:45 AM
white rocket's Avatar
Default Re: Best place to get a block sleeved? (BlueR)
Jesus Marc, that's beautiful :teary eyes:
Old Jan 9, 2006 | 09:57 AM
Marlon88's Avatar
Default Re: Best place to get a block sleeved? (neo_)
Send an IM to Earl and tell him that you are interested in a Benson sleeved block IMHO They are the best out there
Old Jan 9, 2006 | 10:01 AM
Rene M's Avatar
Yummmmmmm..... Yeah i just found that write up ....
What size did you go with and what piston's? Na or boost?
I want to build up a track motor some where in the 2l area but all na.
Old Jan 9, 2006 | 10:07 AM
BlueR's Avatar
84mm, CP mid-dome
Old Jan 9, 2006 | 10:08 AM
migs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rene M &raquo;</TD></TR><TR><TD CLASS="quote">Na or boost? </TD></TR></TABLE>
Those domes are too tall to be boost!
Black R's Avatar
25 Year Member
ERL is good no doubt.
I recently had some excellent dealings with Jim Justice and wouldn't hesitate to recommend him to anyone.
Top notch work and customer service second to none!
Old Jan 9, 2006 | 10:17 AM
92TypeR's Avatar
FSAE
Default Re: Best place to get a block sleeved? (Black R)
Laskey/Benson here!
Excellent turnaround time, EXCELLENT service, and I mean that to the dot. I know people who have waited 3+ months for AEBS to sleeve a motor, and even longer for GE. I got my block 1.5 weeks after initial shipment. Fully assembled and balanced/blueprinted.
85mm 12:1 CP B18C1
Old Jan 9, 2006 | 10:22 AM
Rene M's Avatar
Thats just sex... What trans are you running for those pulls?
Any one use ENDYN pistons yet?
Old Jan 9, 2006 | 10:28 AM
92TypeR's Avatar
FSAE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rene M &raquo;</TD></TR><TR><TD CLASS="quote">Thats just sex... What trans are you running for those pulls?
Any one use ENDYN pistons yet? </TD></TR></TABLE>
'96spec JDM ITR tranny with ATS 4.9 FD
I know a few people running Endyn rollerwave pistons. They offer a good quench area, especially if you have Endyn modify your combustion chambers to pent-clover shaped.
Old Jan 9, 2006 | 10:34 AM
Rene M's Avatar
Your set up sounds real close to what mine is going to be.
Jdm itr 01 trans with the 4.79 in it is on the shelf right now and i was going to put in a set of 12.85 roller wave pistons with the gas holes cerramic tops and coated sides .. All thought i am going to run my ctr cams in it.
Any do's or dont's i should be aware of?
Old Jan 9, 2006 | 10:36 AM
Big Phat R runs Endyn rollerwave pistons. Stock bore I believe with Eagle rods and balanced rotating assembly. His car pulls hard
Old Jan 9, 2006 | 10:37 AM
Bradstard's Avatar
I got mine done by Z10, but it's AEBS closed deck. I personally like the additional strength of the closed deck. I have had no problems with heat so far and the car has seen 8 track days with that motor.
Old Jan 9, 2006 | 10:39 AM
92TypeR's Avatar
FSAE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rene M &raquo;</TD></TR><TR><TD CLASS="quote">Any do's or dont's i should be aware of? </TD></TR></TABLE>
With that compression and that small of cams, your ignition timing will be very conservative. My ignition tables look like a 12psi GSR Motor. If you run a larger cam you bleed off a lot of the compression and will allow you to run more ignition timing, hence more power (not to mention the added power from the cams).
I'm sitting at around 12.2.-12.3:1 right now. About 13thou off the head and 4thou off the block, stock thickness HG.
Ls_dx
Oct 28, 2010 05:28 PM
LoganMantits
Jun 1, 2005 02:03 PM
fast93accord
Nov 17, 2004 01:43 PM
dd PA da
May 4, 2004 08:15 AM
