free play in my steering wheel, tie rods replaced. what can be the problem?
Old Jan 9, 2006 | 09:18 AM
91integraLSVTEC's Avatar
Default free play in my steering wheel, tie rods replaced. what can be the problem?
my steering is very loose, i feel no play in my tie rods, what else can i check for to solve this problem? thanks in advance
Old Jan 9, 2006 | 09:20 AM
x93coupex's Avatar
Default Re: free play in my steering wheel, tie rods replaced. what can be the problem? (91integraLSVTEC)
i heard theres a way to tighten it on the steering box but im not to sure though
Old Jan 9, 2006 | 09:21 AM
litterbox's Avatar
I am a (Trial User) Army
Ah! You must adjust your gearbox
You need a big *** wrench to put around the huge outer lock nut first. Then tighten the middle bolt till you get the amount of play you want.
Here's the correct procedure.
And replace #10 (bushing)
Old Jan 9, 2006 | 09:23 AM
x93coupex's Avatar
Default Re: free play in my steering wheel, tie rods replaced. what can be the problem? (litterbox)
thats some good info littterbox i never actuallyt seen a pic of where you tighten it up from cause i have som play too
Old Jan 9, 2006 | 09:24 AM
InJ3cted's Avatar
and change your RACK END BUSHING #10
http://www.hondaautomotivepart...R+BOX
trust me, search the EF forums for it and you'll see
Adjusting the gearbox is ( for drive side) like replacing the REB for the passenger side
Old Jan 9, 2006 | 09:25 AM
krnnerdboy's Avatar
wow most informative info yet!!
thanx!
Old Jan 9, 2006 | 09:35 AM
Default Re: free play in my steering wheel, tie rods replaced. what can be the problem? (krnnerdboy)
wow. thanks alot guys! thats a really big help!!!
MotorMouth93
Jan 17, 2015 03:58 PM
j4s0n1337
Feb 28, 2012 06:15 PM
j0keefe21
Feb 5, 2009 04:25 PM
Home Skillet
May 6, 2003 07:35 AM
