Rear Disc Parking Brake Question (not about which cables)
Old Jan 9, 2006 | 08:16 AM
PhatBoy5015's Avatar
Default Rear Disc Parking Brake Question (not about which cables)
I was looking at a break-down of the rear disc on a Honda and I don't understand how the parking brake works. I know on most cars with rear disc brakes, there are brake shoes on the inner part the rotor hub. But it doesn't look like that is how these brakes work. If anyone knows, please explain. I need to figure out if the rear disc swap I am looking at is complete. Thanks.
Old Jan 9, 2006 | 08:28 AM
pdiggitydogg's Avatar
simple
You pull the hand brake, which pulls a cable, closing the caliper and putting pad pressure on the rotor. There is a spring on the caliper, which makes the caliper reopen when the cable is slack
its a physical, mechanical brake
Old Jan 9, 2006 | 09:21 AM
Redline96LX's Avatar
* B A N N E D *
Default Re: (pdiggitydogg)
Let me clarify what he said.
There is that rotational spring. Theres a stick coming out of the caliper. The e-brake pulls on a leven which rotates it. inside there is a sort of cam that rotates, thus pushing on the piston. Check http://www.hondapartssource.com for a diagram that should give ya a better idea.
Old Jan 9, 2006 | 09:45 AM
Default Re: (Redline96LX)
Ok thanks. I figured it was simple, but I have never seen a parking brake that actually uses the caliper instead of shoes.
bopbop93030
Jul 7, 2008 12:26 AM
jmk64
Nov 5, 2006 04:50 AM
Turbo Dan
Aug 8, 2006 07:05 AM
mickey513
Oct 2, 2003 04:35 AM
Vinceg99
Nov 21, 2002 05:42 AM
