b-series swap into ef....need your help with mount problem
Old Jan 8, 2006 | 05:41 PM
Wink1100's Avatar
Default b-series swap into ef....need your help with mount problem
haven't done a b-series swap in a longtime, which OEM rear mount, do you use between the transmission and the aftermarket rear urethane mount on the subframe? It's a "T" style mount. 1 hole for the bolt on the mount to the subframe, 1 hole for the bolt mount on the transmission and 2 holes for the bolt mount on the lower transmission. haven't done a b-series swap in awhile, can anyone help me out?
Old Jan 8, 2006 | 07:46 PM
crxnj's Avatar
Default Re: b-series swap into ef....need your help with mount problem (Wink1100)
You need a 90-93 integra rear mount bracket..
Old Jan 8, 2006 | 08:45 PM
payneth's Avatar
Default Re: b-series swap into ef....need your help with mount problem (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">You need a 90-93 integra rear mount bracket..</TD></TR></TABLE>
Old Jan 9, 2006 | 01:12 AM
Mr Synister's Avatar
Default Re: b-series swap into ef....need your help with mount problem (payneth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">You need a 90-93 integra rear mount bracket..</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by payneth &raquo;</TD></TR><TR><TD CLASS="quote">
×2
Old Jan 9, 2006 | 05:31 AM
Wink1100's Avatar
tried that. doesn't work. how about DC rear bracket? I'm using ENJO mounys for the EF to b-series swap.
Old Jan 9, 2006 | 05:26 PM
Wink1100's Avatar
yup. found out today, for enjo ef swap to b-series motor and tranny, u need a DC rear bracket to connect the tranny and motor. basically 94-00 integra
Old Jan 9, 2006 | 06:25 PM
HamiltonRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wink1100 &raquo;</TD></TR><TR><TD CLASS="quote">yup. found out today, for enjo ef swap to b-series motor and tranny, u need a DC rear bracket to connect the tranny and motor. basically 94-00 integra</TD></TR></TABLE>
Goodjob!
I was going to say, eaither or
existanzcivicb20
Apr 18, 2017 03:12 AM
hammergunner
Mar 16, 2009 06:04 AM
dem0nk1d
Nov 21, 2008 09:44 AM
unknown0001
Aug 10, 2005 02:06 PM
unknown0001
Aug 10, 2005 02:04 PM
