charge piping: which is "better" bigger or smaller??
Old Jan 8, 2006 | 05:35 PM
hatchinprogress's Avatar
Default charge piping: which is "better" bigger or smaller??
ok im bout ready to turbo my built (but not sleeved) dohc zc, im going to use a t3 (.42/.48). A guy thats helping me with my project says to use a smaller diameter charge piping and then use a 2.5 dp. so what do you guys say?? (oh and my exhaust is 2.5 all the way back)
(on my last turbo setup i had a t-25 on my stock zc and all of my piping was 2.5, i noticed a bit of turbo lag)
Old Jan 8, 2006 | 05:49 PM
coneheadsracing's Avatar
Default Re: charge piping: which is "better" bigger or smaller?? (hatchinprogress)
personaly i wouldn't go much bigger then the size of the outlet on your turbo. Exhuast, definetly 2.5, not gonna hurt anything by going bigger.
Old Jan 8, 2006 | 05:51 PM
Default Re: charge piping: which is "better" bigger or smaller?? (coneheadsracing)
i dont have the turbo with me right now (it's at my school) and im tryin to order my pipes.....do you (or anyone) know the size of the turbo outlet on a t3?
Old Jan 8, 2006 | 05:52 PM
JDogg's Avatar
you're not gona make a ton of power... 2 to 2.5 inch will work fine.
the bigger the dp and exhaust the better
Old Jan 8, 2006 | 05:55 PM
Default Re: charge piping: which is "better" bigger or smaller?? (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">you're not gona make a ton of power... 2 to 2.5 inch will work fine.
the bigger the dp and exhaust the better</TD></TR></TABLE> yeah i know im gonna make less then i thought i would (people say it's a small turbo...but it's bigger then my old t-25) anyone know the size of the t3 outlet?
Old Jan 8, 2006 | 10:30 PM
second edition's Avatar
im running 2.25 on my zc
Old Jan 9, 2006 | 04:19 AM
Default Re: charge piping: which is "better" bigger or smaller?? (second edition)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by second edition &raquo;</TD></TR><TR><TD CLASS="quote">im running 2.25 on my zc</TD></TR></TABLE> anyone know the size of the turbo outlet??
Old Jan 9, 2006 | 04:22 AM
ccivic's Avatar
I believe it's right around 2".
Old Jan 9, 2006 | 05:36 AM
Turbocivic94's Avatar
2.5" on t/b side and 2.0" on turbo side
Old Jan 9, 2006 | 11:19 AM
Civicman86's Avatar
Default Re: charge piping: which is "better" bigger or smaller?? (Turbocivic94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 &raquo;</TD></TR><TR><TD CLASS="quote">2.5" on t/b side and 2.0" on turbo side</TD></TR></TABLE>
+1
Old Jan 9, 2006 | 11:24 AM
bigdaddyvtec's Avatar
* B A N N E D *
Default Re: charge piping: which is "better" bigger or smaller?? (Civicman86)
2 inch
boostedcivicsir's Avatar
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coneheadsracing &raquo;</TD></TR><TR><TD CLASS="quote">personaly i wouldn't go much bigger then the size of the outlet on your turbo. Exhuast, definetly 2.5, not gonna hurt anything by going bigger.</TD></TR></TABLE>
i would think that you wouldnt need to go bigger than the bore of your tb. but thats my o.o2
EDIT:
keep the hot side the same as the turbo discharge, and the cold side, the same size as the tb.
Old Jan 9, 2006 | 11:32 AM
LoseRPunKx182's Avatar
Default Re: charge piping: which is "better" bigger or smaller?? (boostedcivicsir)
i also wouldn't go bigger then ur throttle body
beepy's Avatar
There is always a balance.
For the charge pipes, the balance is flow vs. volume. The larger the pipes are, the less head loss (pressure drop). For exhaust, the balance is flow vs. noise level and fitment. Go bigger means go louder, and you may find it difficult to fit a 4" downpipe and exhaust.
Charge pipes are generally made too large. While the staple size is 2.5", this size will flow enough to support over 600 horsepower. 2" is actually just fine for up to 350. I run the same turbo you are going to run, and I use 2" charge pipes and 2.5" exhaust, with a full exhaust, cat, and chambered muffler, and lag is not bad.
fullthrottleking
Jul 31, 2008 08:41 PM
chippy
Jan 13, 2006 09:58 PM
HS2G
Apr 13, 2005 10:15 PM
HuskerHybrid
May 14, 2004 11:02 AM
jonnybravo
Nov 19, 2003 11:49 AM
