Finished swap, car won't start.
Old Jan 8, 2006 | 04:24 PM
Lissav's Avatar
Default Finished swap, car won't start.
'93 b18a in a '91 civic, i converted the motor to obd0, used a pr4 ecu.
I am getting spark and fuel, the car turns over but won't start.
Old Jan 8, 2006 | 04:26 PM
si0385.'s Avatar
Default Re: Finished swap, car won't start. (Alexandre!)
double check your timing, check your fireing order
Old Jan 8, 2006 | 04:34 PM
kulangot's Avatar
Default Re: Finished swap, car won't start. (jaydeum4lyfe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydeum4lyfe &raquo;</TD></TR><TR><TD CLASS="quote">double check your timing, check your fireing order</TD></TR></TABLE>
if your getting spark and fuel..check your timing..
Old Jan 8, 2006 | 05:17 PM
Lissav's Avatar
Default Re: Finished swap, car won't start. (kulangot)
I checked the firing order, it's fine. Also there shouldn't be a timing problem, at least i don't think???
Old Jan 8, 2006 | 05:30 PM
si0385.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alexandre! &raquo;</TD></TR><TR><TD CLASS="quote">I checked the firing order, it's fine. Also there shouldn't be a timing problem, at least i don't think??? </TD></TR></TABLE>
i would check anyways if i were you to make sure
Old Jan 8, 2006 | 05:31 PM
crxrsx's Avatar
how do i post a pic
Old Jan 8, 2006 | 05:46 PM
Lissav's Avatar
Default Re: Finished swap, car won't start. (crxrsx)
"[img]"http://linktoyourpicgoeshere.jpg"[/img]"
Just take out the quotations (")
Old Jan 8, 2006 | 06:03 PM
naptownrex's Avatar
Check your sensors... If one of them got busted during the transplant, the car may not start. I know that when I did my swap, my MAP sensor was bad, and it took ALOT of cranking for it to finally start. Is your ECU showing any codes? It sounds like a sensor problem to me, so thats where I would start.
Old Jan 10, 2006 | 11:31 AM
90jdmcrxdude's Avatar
Check the wirings and plugs for dizzy. Or maybe the Crank shaft position senor.(internal ign. coil) wires feed into the dizzy. from ECU
EJ ITO
26
Mar 22, 2007 05:41 AM
skeematic
Nov 24, 2004 10:53 PM
kaoss_11
10
Aug 22, 2004 06:28 PM
The OEMobile
Aug 17, 2003 05:05 PM
The OEMobile
Aug 17, 2003 04:42 PM
