bottom molding
Old Jan 8, 2006 | 03:28 PM
j_man104's Avatar
Default bottom molding
Ok, my door is desperatley in need of an alignment, to get to the bolts to do so I need to remove the fender. When I went to remove the fender the very last bolt I found it under the bottom trim (under the door), I took the screws out of the bottom on the underside of the car, but still stuck.
SO... my question is, how do I get the molding off of the hangers without tearing it up and being able to get it back on? I drive a 95 eg, thanks for the help!
Old Jan 8, 2006 | 04:24 PM
highroller54's Avatar
Default Re: bottom molding (j_man104)
I just had the fenders off my eg but I didn't pull the lower molding off, I just pulled the front corner down with a big screw driver and used a socket and extesion to get at the bolt. I was carful and didn't hurt anything.
Old Jan 8, 2006 | 04:29 PM
j_man104's Avatar
Yeah I tried that too, but it's on there pretty good. I couldn't get it down enough to get the bolt out.
Old Jan 9, 2006 | 06:50 PM
did you pull all the bolts from the inner fender/ mud flap area?
Old Jan 11, 2006 | 08:31 PM
j_man104's Avatar
Default Re: bottom molding (highroller54)
Yes, I got them all except for that last one under the molding.
bopbop93030
May 9, 2009 09:38 AM
Khanster
Feb 3, 2009 10:57 PM
venessEK
Jul 14, 2008 08:06 AM
3lo
Apr 6, 2008 09:57 AM
PY2KITR1060
May 19, 2002 07:25 PM
