brand new jdm d15b burning coolant
Old Jan 8, 2006 | 01:49 PM
ham's Avatar
ham
Default brand new jdm d15b burning coolant
i swapped a jdm d15b into my coupe and ever since the first time it warmed up i can smell burning coolant coming out the tail pipe.
i did a bunch of tests and its almost been a month now and nothing is happening. i only had to add a little coolant once. compression, leakdown, pressure test, oil... everything checks ok. i also checked the iacv.
compression: 205-210 psi accross
leakdown was perfect and no bubbles in the coolant.
Modified by ham at 4:21 PM 2/25/2006
Old Jan 8, 2006 | 04:38 PM
sheBangZ's Avatar
Default Re: brand new jdm d15b burning coolant (ham)
headgasket
Old Jan 8, 2006 | 04:40 PM
.Beaver's Avatar
Bloody Beaver
Default Re: brand new jdm d15b burning coolant (sheBangZ)
a used swapped motor is brand new?
Old Jan 8, 2006 | 04:58 PM
ham's Avatar
ham
Default Re: brand new jdm d15b burning coolant (.Beaver)
"new" jdm. it looks brand new but i has some mileage from the civic VTI it came out of
Old Jan 9, 2006 | 03:30 AM
ham's Avatar
ham
bump, i dont want to tear my motor apart and find nothing.....it could be something simple
Old Jan 9, 2006 | 08:44 AM
ham's Avatar
ham
pulled the plugs.... they look normal
Old Jan 9, 2006 | 03:08 PM
ham's Avatar
ham
no ideas?
Old Jan 9, 2006 | 03:53 PM
northkai3's Avatar
did u mess with the im when u swapped the motor or did use use the one already on there?
Old Jan 9, 2006 | 04:10 PM
ham's Avatar
ham
Default Re: brand new jdm d15b burning coolant (northkai3)
its completely untouched, just dropped it in.
Old Jan 9, 2006 | 06:56 PM
EGdrop6's Avatar
i have the same motor and i go through coolant like crazy. i dont know whats the probelm either...it could possibly be my headgasket. i always end up refilling my coolant box like every month
Old Jan 9, 2006 | 09:01 PM
Kosoku's Avatar
If it was the headgasket your oil would be a milky coffee color and the car would consistently overheat. Does that for subarus anyways...
Old Jan 9, 2006 | 10:42 PM
lemon_juice's Avatar
are u sure your burning it? or is it leaking and ull notice u need to refill?.
Old Jan 10, 2006 | 12:07 AM
EGdrop6's Avatar
Default Re: brand new jdm d15b burning coolant (lemon_juice)
no signs of leaks..just constantly refilling it more than usual.
Old Jan 10, 2006 | 03:36 AM
ham's Avatar
ham
i stick my nose in the tailpipe and i can smell it, and thats the only place i can smell it. it stinks whenever i get out of the car... took me a while to figure out its coming from the tailpipe.
Old Jan 10, 2006 | 12:55 PM
ham's Avatar
ham
i hate my life
Old Jan 10, 2006 | 01:10 PM
lazie's Avatar
its possible that your theromostat isnt opening up all the way and its just boiling your coolant
Old Jan 10, 2006 | 05:25 PM
ham's Avatar
ham
Default Re: (lazie)
its not overheating, i have no driveability issues.
Old Jan 10, 2006 | 07:49 PM
Kosoku's Avatar
So it smells sweet right? Are you getting any white smoke?
Old Jan 11, 2006 | 03:44 AM
ham's Avatar
ham
Default Re: (Kosoku)
no white smoke is noticeable... again ive only had to add once. it just STINKS REALLY BAD. people tell me they smell burning coolant. its definitely coming out the tailpipe and not burning or leaking anywhere else.
Old Jan 11, 2006 | 05:42 AM
91integraLSVTEC's Avatar
Default Re: (ham)
you cant just drop that motor in you have to change a few parts. change your thermostat and obviosly you have a pin hole leak somewhere thats leaking on your exhaust pipe. find white stains on your engine bay, that would be an indication that coolant leaked and burned there.
Old Jan 11, 2006 | 07:04 AM
b20vtechatch
Guest
Posts: n/a
Default Re: (91integraLSVTEC)
d15b jdm water pumps suck you should have changed that before you droped the motor in.
Old Jan 11, 2006 | 12:39 PM
ham's Avatar
ham
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91integraLSVTEC &raquo;</TD></TR><TR><TD CLASS="quote">you cant just drop that motor in you have to change a few parts. change your thermostat and obviosly you have a pin hole leak somewhere thats leaking on your exhaust pipe. find white stains on your engine bay, that would be an indication that coolant leaked and burned there.</TD></TR></TABLE>
you didnt pay attention to the post, i said its burning coolant through the combustion chamber. and yes i can just drop a motor in, the maintenance is over rated. i didnt even change the plugs/wires. timing belt i agree with because its 15 year old rubber. i have no smell or signs of coolant leaking under the hood.
Old Jan 11, 2006 | 12:47 PM
Good ol' Screwtape's Avatar
Multi-paradigm
Default Re: (ham)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham &raquo;</TD></TR><TR><TD CLASS="quote">
its burning coolant through the combustion chamber.</TD></TR></TABLE>
If coolant is burning with A/F mixture in the cylinders, why don't you have white smoke? Also, what type of exhaust setup are you running? How many miles on the cat? And please, describe the actual smell you're smelling.
Old Jan 11, 2006 | 12:50 PM
1SickEG's Avatar
ah man that sux
Old Jan 11, 2006 | 03:31 PM
ham's Avatar
ham
Default Re: (Screwtape.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Screwtape. &raquo;</TD></TR><TR><TD CLASS="quote">
If coolant is burning with A/F mixture in the cylinders, why don't you have white smoke? Also, what type of exhaust setup are you running? How many miles on the cat? And please, describe the actual smell you're smelling.</TD></TR></TABLE>
its very little, like i said i only had to add coolant once. the smell is sweeter then just the smell of coolant but smells like coolant still. the exhaust is stock oem (new).
