91 civic 4d with 91 teg rear disc....which e-brake cables do I use?
Like the title says....I hear the civic e-brake cables are too short or something....should use the teg e-brake cables?............ hit me
I used 95 integra cables and they bolted up perfectly. If you have the 91 teg cables I believe those should work also? Maybe? Somebody else will know for sure.
when i did full 00si brakes on my 91 si i used the cables off the 00 si, and it worked.
So i assume you use what you have, if your using da brakes, use da cable? etc
Im sure you can mis match cables to different brake types, but don't take my word for it.
GL with the brake upgrade, it sure does help out!
paid....nothing cause my friend wrecked his teg.....i have another set for sale....same ones....off of a 93 gsr if your looking for same stuff...everything you need whole sus.
racingant
Apr 23, 2006 08:54 PM
greatgraffini
13
Dec 5, 2003 12:51 PM
Sleeper Sii
Sep 15, 2002 03:44 PM
