Q's-Del Sol/GSR swap
Old Jan 7, 2006 | 11:55 PM
bjfisher's Avatar
Default Q's-Del Sol/GSR swap
ok i just got a 93 del sol s.....i also have a totalled 95 gsr...can i use everything from the gsr to swap the motor in the sol?im pretty sure the wiring and mounts will be ok,but i was kinda unsure about the shift linkage....if theres anything i cant use,and/or have to modify for this to work,id appreciate the help....thanks in advance....
Old Jan 8, 2006 | 01:55 AM
whoDAT's Avatar
Default Re: Q's-Del Sol/GSR swap (bjfisher)
search, buddy o' pal, SEARCH. this has been covered since the stone ages. check the FAQ'S, and oh yeah, SEARCH!!! you will need the DOHC del sol shift linkage... to think about it... if you don't even know the answers to your own questions, you really shouldn't even be attempting this swap....
Old Jan 8, 2006 | 05:44 AM
bjfisher's Avatar
its not the first b series - 5g swap ive done,i think ill be fine
first del sol swap,yes.well,thanks about the linkage...
ejv8s10
Sep 3, 2014 11:52 AM
mish__
Mar 18, 2011 05:13 PM
bo98teg
Jul 7, 2010 03:20 PM
roque-pr
19
Mar 24, 2010 05:21 PM
