Where do you get the Vband for turbo outlet like on a GT42R or Holset HY35?
I'm getting a Holset HY35 that has the Vband flange for the compressor outlet, I don't have the turbo yet but I'm assuming it's either 2" or 2.25" and it's obviously aluminum.
Now would just a regular exhaust Vband flange and clamp of the same size do the trick? Would that be prone to leaking? any suggestions? what do the folks with the fancy GT42R's do? PICS?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jays91DXhatch »</TD></TR><TR><TD CLASS="quote">I'm getting a Holset HY35 that has the Vband flange for the compressor outlet, I don't have the turbo yet but I'm assuming it's either 2" or 2.25" and it's obviously aluminum.
Now would just a regular exhaust Vband flange and clamp of the same size do the trick? Would that be prone to leaking? any suggestions? what do the folks with the fancy GT42R's do? PICS?</TD></TR></TABLE>
The Clamp/ Flange is different from any other standard flange.
You need to order them up when you order the Turbo.
I know precision stock thems and Im sure phoenix turbo.
