Cloudy Headlights
Old Jan 7, 2006 | 08:08 PM
dyslogical's Avatar
Default Cloudy Headlights
I apologize in advance for such a noobish question.
My left headlight needs cleaning because it's a little cloudy
Does anyone know how to remove the goopy stuff that seals the front headlight cover to the main housing?
It's like a tar glue and I'm thinking of heating it up. Any suggestions?
Also, to remove the entire headlight housing, what other bolts do I need to remove other than the 2 immediately visible ones on top?
Has anyone cleaned their headlights before? Thanks
Old Jan 7, 2006 | 08:12 PM
ekcivic9's Avatar
with all that effort spent on posting pictures... a simple search would have yeilded answers.
Your search for cleaning headlights returned 21 results.
to sum things up, you can remove your headlights, there are 2 additional 10mm bolts hidden on under the bumper. in order to get the seal apart from the light, you have to bake the housings in the oven.
are you sure the haze is inside the lense or outside?
Old Jan 7, 2006 | 08:21 PM
dyslogical's Avatar
Default Re: (ekcivic9)
Thanks, I tried a search before posting but I missed the radio button to search posts and thread titles. Thanks though
Old Jan 7, 2006 | 08:41 PM
M2nR's Avatar
Default Re: (dyslogical)
yah bake your headlight for 5 mins @ 250degrees they should come off, but be carefull dont pull to fast dont pull to hard... if its stilll hard rebake as needed.
also besides the two visible bolts there are two other 10mm bolts, one to the right (driver side, vise versa for passenger side) and another one right under the headlight... (bumper must be removed to acess these)
good luck with it
Old Jan 7, 2006 | 08:42 PM
OogalyDoogaly's Avatar
First, if the haze is from the inside, which I doubt, you need to remove the headlight (you need to remove bumper to reach the other bolts) and bake it in an oven. I'm not sure about the temperature and time, but I think it was around 250F for about 12 minutes (NOT SURE). Then you pry open the housing.
Second, if the haze is from the outside (which I tihnk it is), WET sand the lense (not sure what grit) and then apply plastic polish and it should look brand new. Hope that helps
Old Jan 7, 2006 | 08:48 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: (OogalyDoogaly)
wet sand with about 1500-2000 grit, then go get some 3M Perfect It II rubbing compound. Good ****.
Old Jan 7, 2006 | 08:50 PM
SovXietday's Avatar
Default Re: (M2nR22)
Try wetsanding and polishing the outside of the headlight first. Then take it off if that doesn't clear up the problem.
^^ He beat me to it.
Modified by SovXietday at 1:09 AM 1/8/2006
Old Jan 7, 2006 | 10:28 PM
lloydadvance's Avatar
there will be another bolt at the bottom. even if you clean them more condensation will just reproduce in the head lights it going to happen and theres nothing you can do but keep cleaning
krazzykilla420
Honda Civic (2001 - 2005)
Jan 21, 2008 12:18 PM
Honder07si
Honda Civic (2006 - 2015)
Apr 24, 2007 01:54 AM
lx130
Jun 3, 2006 11:44 AM
