Raising Idle via Idle Screw
Old Jan 7, 2006 | 07:01 PM
vinuneuro's Avatar
Default Raising Idle via Idle Screw
A car that I'm looking at has aftermarket motor mount inserts (front and back). Because of this, at idle there's quite a bit of vibration. However, at around 1k it's fine. So...would I create any problems if I raised the idle to 1k by adjusting the idle screw on the t-body?
Old Jan 7, 2006 | 07:23 PM
Hawkze_2.3's Avatar
Default Re: Raising Idle via Idle Screw (vinuneuro)
You might use 1% more gas.
It wouldn't cause any other problems...
Old Jan 7, 2006 | 07:42 PM
amckee's Avatar
Default Re: Raising Idle via Idle Screw (Hawkze_2.3)
Don't go any higher than that or you could get an idle surge loop going. Fuel injector cutoff with the throttle plate closed starts somewhere around 1100-1200.
Old Jan 14, 2006 | 05:26 PM
racericky's Avatar
bla bla bla
Old Jan 14, 2006 | 05:27 PM
racericky's Avatar
bla bla
Old Jan 14, 2006 | 06:36 PM
vinuneuro's Avatar
Default Re: Raising Idle via Idle Screw (racericky)
wtf is this
Run Away
Mar 11, 2006 05:08 PM
turbotime
Oct 24, 2005 12:01 PM
