SRS light on . 01 Accord..
Old Jan 7, 2006 | 06:52 PM
phillbo's Avatar
Default SRS light on . 01 Accord..
What causes this and how do I get it to turn off?
thanks for any help you can provide.
Old Jan 7, 2006 | 07:05 PM
i_kick_turtles's Avatar
Default Re: SRS light on . 01 Accord.. (phillbo)
When you start your car, the SRS system goes through a self check. If there is something wrong, the light comes on, and the system deactivates. Start by checking your fuse.
Old Jan 7, 2006 | 07:16 PM
phillbo's Avatar
Default Re: SRS light on . 01 Accord.. (I R Tylor)
What does SRS stand for and do you know which fuse to look at ? I lost my manual and it just tripped on today. Does this mean my airbags have been deactivated ?
Old Jan 7, 2006 | 08:45 PM
Ross 2.0's Avatar
In a Junkyard near you.
Supplimentary Restraint System.
Your airbags will be affected depending on the code. It's dangerous for an untrained owner to diagnose an SRS problem. If you do the wrong thing you could die. Not trying to scare you, just trying to warn you.
But more than likely your drivers seat belt bucke has malfunctioned (electrical part), or you have a weak battery (or just replaced it).
If you don't have a battery problem I would swing it by a dealer and have them pull the code. If it is the buckle that will be covered under the Lifetime seatbelt warranty (all hondas have this). And your SRS computer is covered by an 8 year 80,000 mile warranty. So you should be ok.
Let me know what you find out.
Good Luck
Old Jan 9, 2006 | 04:09 PM
phillbo's Avatar
Default Re: (MooGoCow3)
Thank you for the reply. I will have the codes read to see what the issue is.
CrankyAmps
Apr 14, 2017 04:06 PM
PsXtreme
Sep 13, 2016 05:17 PM
hondamanf22
Aug 20, 2008 06:21 PM
dansaleen_04
Jun 28, 2006 12:06 PM
** OF HAZARD
Aug 26, 2002 11:23 PM
