starting problem
car isnt starting. i checked the battery, and starter. when i try to start the car, i hear a clicking sound (i think its from the main relay) and all the lights on the gauge cluster turn on, but thats it. can someone help me out? thanks
THE CAR WONT CRANK EITHER. IVE TRIED REPLACING THE STARTER, MAIN RELAY, AND BATTERY. IM PRETTY SURE THAT THE FUEL PUMP IS PRIMING BECAUSE I HEAR A HUMMING NOISE WHEN I TURN THE KEY. COULD IT BE THE IGNITION SWITCH? THANKS FOR THE RESPONSES.
yes the igintion switch will stop the car from even trying to cranck over. i have had to go through many igintion switchs.
the switch is connected to the starter...if is bad it won't send the signal over to the starter. there for it will not cranck. you may want to check yyour starter and make sure everything is connected.
If you have all ready replaced everything then you may need to buy a new iginition switch.
cruz_96LS
Jul 27, 2010 03:44 AM
Honda Virgin
Jun 2, 2004 12:34 PM
