New to Crome need help
Im looking for a bin for a stock H23 non vtec. All im wanting is for the exact same fuel and ignition tables that the P14 have. I have a Chipped p06. Ive tryed to use a P30 rom and run it but it seems to run really lean. So im scared to even drive it. I just basically want to have the P14 maps and then have the FTL and FTS active.
Go to moates.net. I'm not sure if they have the bins on there or where you could get them. Contact them, and I'm sure they could tell you were to get them if they don't have them. That's where I got my burner and data logger. They are VERY helpful.
Do it right and stick with chrome. AEM won't give you as many options. AEM has a LOT of stuff, but in the long run, depending on how far you want to go, Chrome is more robust.
Don't shell out the money for AEM.
Do this,
In CROME start out with a basemap for another engine, I used a JDM B16a3(or somethin like that), then change the multipliers for engine size AND injector size(if you are using bigger injectors), I did this and it was almost spot on believe it or not.. then of course you will have to disable VTEC and all the VTEC options as well so you won't throw a code.. also change rev limits and everything of course..
then get a wideband and tune it..
