Anyone have the Mugen N1 ECU????
Old Mar 19, 2002 | 09:21 PM
Area51typeR's Avatar
Default Anyone have the Mugen N1 ECU????
I was wondering when VTEC kicks in and where the rev limit is at?
Old Mar 19, 2002 | 09:23 PM
tjtruong's Avatar
New User
Default Re: Anyone have the Mugen N1 ECU???? (Area51typeR)
i believe it kicks in at 4600 and redlines at 9100. Last time i dynoed at Area 51, i put in the Mugen ECU just for kicks cuz EP let me try it out and it made good progress in the midrange even though my car is stock. Very good upgrade if you are gonna track your car.
tj
Old Mar 19, 2002 | 09:25 PM
Type Goch's Avatar
New User
Default Re: Anyone have the Mugen N1 ECU???? (tjtruong)
Robbie? Track? No way~
Taken from Kingmotorsports.com
This is specially mapped to the fuel mixture, ignition timing, and combustion. The rev limit is increased to 9,100 rpm from the normal 8,400 rpm, and the VTEC valve timing changeover point is lowered to 4,700 rpm from the normal 5,300 rpm. It is highly recommended that reinforced valve springs be fitted if this E.C.U. is used.
Old Mar 19, 2002 | 09:31 PM
tjtruong's Avatar
New User
Default Re: Anyone have the Mugen N1 ECU???? (Type Goch)
i got the dyno sheet if you need it!!
tj
Old Mar 19, 2002 | 09:34 PM
ntt's Avatar
ntt
I'd like to see the dyno sheet.
Not because I don't believe you, but because I'm an info-junkie.
ntt
Old Mar 19, 2002 | 09:35 PM
Type Goch's Avatar
New User
I believe you, I was just taking some info off the website.
Fuminsho's Avatar
tj,
Do you mean "stock", as in zero upgrades? Nothing at all? Let me know... I'm very interested in the N1 myself And did you use the wire harness for it also?
Old Mar 19, 2002 | 09:36 PM
B2FiNiTY's Avatar
Default Re: Anyone have the Mugen N1 ECU???? (Fuminsho)
He had a comptech drop in and apexi n1 at the time.
Old Mar 19, 2002 | 09:48 PM
Default Re: Anyone have the Mugen N1 ECU???? (B2FiNiTY)
Cool, thanks guys...my friend had one laying around..so i decided to borrow it while he is in Japan...i was just wondering cause my VAFC is still in my car and i didnt know where the vtec was supposed to be... but we are going to re-tune my car with that computer and see if i can gain more power with the higher rev limit...so ill hope to see you all at the track at the end of the month!!!!!!!!!!!!!
Old Mar 20, 2002 | 08:40 AM
Dropspeed's Avatar
I have had few conversations with Bob @ King regarding the ECU. The Mugen ecu is great if you do not plan on running cams at all. They have tryed the ecu with different cams and it just didn't perform well so its not recommended.
Mattj
Old Mar 20, 2002 | 08:47 AM
BABY NSX's Avatar
Default Re: Anyone have the Mugen N1 ECU???? (Dropspeed)
Mattj
But I thought all our engines had cams in them
Old Mar 20, 2002 | 08:52 AM
Fuminsho's Avatar
Default Re: Anyone have the Mugen N1 ECU???? (BABY NSX)
Did you ask them about the mugen cams?
Old Mar 20, 2002 | 08:55 AM
Rob :190:'s Avatar
TypeRforwhenIB18 has one in his car, but its not running right cause its not tuned yet. I had no idea the ECU could do anything for stock motors....
also, on a Type R, are valve springs necessary? since EP proved the Mugen springs were just ITR springs?
[Modified by Rob1035, 2:36 PM 3/20/2002]
Old Mar 20, 2002 | 11:20 AM
B2FiNiTY's Avatar
Default Re: Anyone have the Mugen N1 ECU???? (Rob1035)
You answered your own question. Not needed at least with the stock cams...
Old Mar 20, 2002 | 11:21 AM
Rob :190:'s Avatar
ha, i love doing that
Old Mar 20, 2002 | 11:24 AM
Big Phat R's Avatar
I have the N1 ECU. With stock cams I was able to get just under 190 whp SAE. It works well with a straight pipe and your powerband is a small bit bigger. Vtec engages earlier. I bought it used from a guy in Oregon.
Old Mar 20, 2002 | 11:25 AM
Casey's Avatar
yeah, id recommend some dyno tuning if coupled with a vafc and high output motor, but other than that it is a nice ecu
blkboyan
Nov 8, 2006 08:43 PM
98 Spec R
Dec 4, 2005 08:28 PM
Snoppy
Feb 15, 2004 08:01 PM
bcrl
Feb 18, 2003 12:19 PM
