WTB: GSR Crank!!! ITR Pistons, ITR Valves
looking for a gsr crank, that never had a spun bearing and in good shape.
also looking for standard bore usdm type r piston set including the rings etc... , ITR Valves, and USpec ITR Cams.
Modified by bucdenny at 9:37 AM 1/7/2006
Modified by bucdenny at 11:38 AM 1/7/2006
if you buy used oem pistons, YOU NEED TO GO TO HONDA AND BUY NEW RINGS.
you pull a piston out, you cant put used rings back in, thats crazy
i got new oem piston ring set and new itr intake valves in honda oem packaging 250 shipped for 8 valves and piston rings
mRek9R
May 27, 2010 05:47 AM
