Help With Tire mounting
Yes the tire is on the wheel but no matter what I try air gets by the bead. I am using a shop compressor at work. It puts out 150psi max.
No, it won't seat at all. I tried various methods but in one spot air always gets by. Even after spinning the tire on the rim air gets by in various places. Its a Renn Tech Wheel tire size 245/35-19.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94B18Civic »</TD></TR><TR><TD CLASS="quote">tire size 245/35-19.</TD></TR></TABLE>
On a Civic???
On a Civic???
lube the bead up good. make sure the bottom part of the valve stem isn't on the way of the bead. what I usually do is that I break the beads down again and have a buddy raise the bottom part of the tire at all sides then put air in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pingaturbo »</TD></TR><TR><TD CLASS="quote">Make sure you didn't rip the bead while mounting the tire on the wheel.</TD></TR></TABLE>
I was thinking the same thing...
im stuck on this, we need more info...... try mounting a 325/25/20, that's not fun
Agree there might be a small tear somewhere
Yup. The tire was ripped by the valve stem. After removing the tire I also noticed a label on the inside of the wheel (tire side) that was scrapped off somewhat. The tire should have originally been mounted with the wheel upside down. The wheel was on a Benz SL 65.
hondaguyef
Sep 29, 2004 02:52 AM
