90 CRX DX ZC Swap,fire on all cyclinders, fuel injectors are working, no Start
hey this car was hacked up when i got it, its not my car just doin a repair job. well the harness was hacked, well the inside harness was fixed and converted for mpfi and everything is right, no codes , firing on all four cylinders and fuel all the grounds are good, switched injectors, resistor box, checked all fuses and tried another ecu, this engine came out of a running car... i did not personally do it, i get stuck fixing hack jobs. well anyone got any suggestions on what to check for, oh yea new dizzy, he said he put a new fuel pump in and the car has been under water. ps new harness made from dx harness, 2nd one i have done and its all correct checked it several times, and the timing is right.
not but no backfiring just like one hit when u first try to start it.
ok now the car died again, no check engine lights, it was runnin like **** when u floored it, then we let it idle shut it off and wont' start back up, all it does is backfire, i have fuel and spark, and no codes, anyone got any ideas, note day before ran great no codes...now it won't start? any ideas...i hate this car
we did relocate the battery to the rear... we had the car on the lift and it started fine, then we test drove it,well tried too and it was runnin like ****, so we turned it off and it never started again..but i do have spark and fuel...i checked the grounds but im movin the battery back to the front and try it again, and i have good compression across all 4. well anyone ran into this before?
tailoredtune
20
Nov 1, 2011 08:15 PM
crexer
Dec 27, 2004 07:10 PM
