Turbo question
Old Jan 6, 2006 | 04:37 PM
WHiTETYPEs's Avatar
Default Turbo question
I currently have a 1998 Honda Civic EX (stock motor, stock everything) and I'm planning on purchasing the t3 turbo kit from xs racing my question is what else would I need to get besides
turbo kit
450cc Injectors
new clutch
ecu tuned
2.5" - 3" exhaust
Will my motor still be safe? Or will I have to do other engine mods?
Edit* before someone says something (Guess this would be better in the forced induction topic)
Old Jan 6, 2006 | 05:08 PM
MikeD718's Avatar
Default Re: Turbo question (eK9RepreSenT)
how many psi do you plan on running? i ran 8-9 pounds daily with my old T3 on my stock internals d16y8 with out a problem. what fuel tuning program do u plan on running? post whats included with the turbo kit so we can tell you if there is anthing else you need.
Old Jan 6, 2006 | 05:13 PM
WHiTETYPEs's Avatar
Default Re: Turbo question (MikeD718)
Sorry. Better?
Old Jan 6, 2006 | 05:19 PM
MikeD718's Avatar
looks like an ssautochrome kit i havent heard many good things about them, you might want to search for info on "bracing" that mani. also if you are going to turbo it you will want to get some head sutds, d-series have a tendency to experience head lift under boost which results in a blown headgasket. (take it from a guy who knows lol) also a walbro fuel pump will help if you are gonna run 450's
Old Jan 6, 2006 | 05:25 PM
WHiTETYPEs's Avatar
thanx for the info well here is what another forum said
http://www.7thgencivic.com/for...17031
Should I just get the kit and buy a different manifold? and I should be safe?
Edit: plan on using 8-10 psi
Old Jan 6, 2006 | 05:28 PM
J1A1H's Avatar
looks like a turbo kit you can get off ebay for $800-1000.. i have been very tempted to buy one but i am very worried about how good they actually are.
Old Jan 6, 2006 | 05:31 PM
MikeD718's Avatar
how much are they asking for it? to be honest i would just piece one togegther with parts that you know are quality. think about down the road, you could get this kit and have it break or spend just a littel bit extra cash and not have the headaches.
just my $.02
Old Jan 6, 2006 | 05:32 PM
SOHCD16y8's Avatar
YOur motor will be safe with a good tune. DOnt think in terms of psi but more HP. The average stock D16 can safely run 200-220whp. And then there are a few in the 300's on stock internals.
Old Jan 6, 2006 | 05:33 PM
WHiTETYPEs's Avatar
What parts should I keep and what parts shouldn't I keep? cuz im only hearing bad things about the manifold...is tehre turbo still good and everything else?
Old Jan 6, 2006 | 05:34 PM
mx621's Avatar
Default Re: (J1A1H)
the compressor housing's on them ssauto/xs turbos are glued together, the quality of them kits are a big . herd horror stories on here about them
Old Jan 6, 2006 | 05:35 PM
MikeD718's Avatar
Default Re: (SOHCD16y8)
https://honda-tech.com/zerothread?id=1460732
this is a recent post about ssautochrome's stuff. some good and some bad...mostly bad
Old Jan 6, 2006 | 05:36 PM
WHiTETYPEs's Avatar
Default Re: (mx621)
well Im on a budget. what are some decent turvo's that I won't have to worry about going for
Old Jan 6, 2006 | 05:48 PM
SOHCD16y8's Avatar
Save your money, Do it once, Do it right
Old Jan 6, 2006 | 05:53 PM
Br1anPham's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCD16y8 &raquo;</TD></TR><TR><TD CLASS="quote">Save your money, Do it once, Do it right</TD></TR></TABLE>
Or don't do it.
Or get a cast CX log style maniold and go HMT style because those cast manifolds are a lot sturdier then the SSAutocrome stuff. Everything else from that kit should work decent.
and aside from your list, a walbro fuel pump wouldnt hurt.
Old Jan 7, 2006 | 09:25 AM
turbod ek's Avatar
i wouldnt run no more then 7 pounds i was pushing 10 and my **** blew up.
big-cat
14
Feb 22, 2006 01:33 PM
WHiTETYPEs
Jan 7, 2006 06:33 AM
..::91TEG-G2::..
Feb 2, 2004 01:01 PM
redteg
Jan 16, 2003 06:22 PM
01gizzer
Nov 1, 2002 08:01 PM
