90 SI HB With GSR Speedo cable Question???
Ok so I have an EF hatch (90 Si) that I just got done putting a gsr motor swap into, and something I never thought about or even knew about for that matter was the Speedometer cable, the GSR doesn't have one...its got a 3 wire speed sensor so I need to know if anyone has tried converting this problem to that it can work otherwise I won't have a speedometer, not that big of a deal I know, but I would still like to know how fast I'm going when there is a damn pig
on the road with me and no one else to pace with.
Modified by red_honda_racer at 11:28 PM 1/6/2006
You either need to pull the old cable VSS out of your stock motor or get an electronic gauge. Im doing the 99' Si Cluster swap any day now provided my friend pulls through with the cluster. It's nothing hard, just a matter of running a signal wire to your cluster, and power and ground to your VSS. Chances are your better off with your old VSS.
kin_8
Oct 9, 2005 08:40 AM
wickedEFguy
Dec 16, 2002 03:51 PM
