Clutch Slave Cyl. replacement,Quick question
Old Jan 6, 2006 | 11:30 AM
Brycen's Avatar
Default Clutch Slave Cyl. replacement,Quick question
Hey guys just wanted to know what is the easiest way to re-pressurize the clutch after replacing the slave cyl?My clutch took a **** while getting movies the other night the pedal goes to the floor and stays there does not respring back up.I notcied that the resivor was empty and the slave cyl is leaking the fluid pretty badly.Anyone know if there is a tool i can use other than 2 people bleeding the thing.All the help is much appriciated.
Old Jan 6, 2006 | 11:47 AM
bluskye's Avatar
Default Re: Clutch Slave Cyl. replacement,Quick question (Brycen)
one man brake bleeder, tasauto.com has one.
Old Jan 6, 2006 | 11:50 AM
hondadude's Avatar
Go to the local Co-op or animal supply house and get a BIG syringe, and some tubing to fit over the end of it...fill the syringe with brake fluid and inject it into the bleeder screw on the slave until you see the fluid rise in the reservoir.
Another way to do this job and not have to bleed at all, depends on model& year; take the slave off the trans housing and raise it higher than the reservoir, then change Slaves while holding it up high. you can have the bleed screw open and compress the slave cylinder to push out the air .....then close bleeder screw and put the slave back onto the clutch housing.
Check up under the dash to be sure the Master isn't leaking as well
Best of luck I hope this helps you
Old Jan 6, 2006 | 12:02 PM
Brycen's Avatar
Default Re: Clutch Slave Cyl. replacement,Quick question (hondadude)
thanks alot guys this helps alot.Let me try it and we will see what happends.When i was waiting for a tow truck on Wednesday i did check to make sure it was not the master cyl. then the tow guy came lifted the car and said ohh **** dude your leaking stuff all over the place, but nothing wrong with the master so that is good.
Old Jan 6, 2006 | 02:30 PM
Brycen's Avatar
wasen't as hard as i thought t would be.But when i pulled the old slave cyl out and replaced with a new one the whole inside just came sliding out when i took off the boot,not to good.thanks for your guys help much appriciated. bump
Old Jan 9, 2006 | 05:49 PM
accordtype R's Avatar
you can push in the slave cylinder with tyour hand and close the bleeder its not too hard
07FG2
Honda Civic (2006 - 2015)
11
Jan 10, 2009 02:11 PM
Mr. Eric
Nov 18, 2008 09:30 AM
gsr1289
Aug 22, 2006 07:11 PM
tytyguy
Dec 3, 2005 02:32 AM
MrEg
Aug 24, 2003 08:45 PM
