transmisson problems!!!! please help!!
Old Jan 6, 2006 | 09:07 AM
Eg6_rAcEr's Avatar
Default transmisson problems!!!! please help!!
Well i have a 95 gsr motor in my hatch and all the transmisson components are giving me problems. The problems i am having are the clutch pedal feels much firmer then stock, when i hold in the clutch pedal while it is in gear it feels like the car wants to die out like im not holding the pedal in. Just recentely while in first it has died out even though the pedal is all the way down. The last problem is that the shifter does not go in smoothly i have to force it to go into first while at a complete stop and while driving second and third do not go in smooth either and the tend to grind some times. I cant figure out what the problem is soo any input would be appericated. thanks for the help.
Old Jan 6, 2006 | 09:32 AM
x93coupex's Avatar
Default Re: transmisson problems!!!! please help!! (Eg6_rAcEr)
did you check all the fluids clutch and tranny
Old Jan 6, 2006 | 09:34 AM
x93coupex's Avatar
Default Re: transmisson problems!!!! please help!! (x93coupex)
or it could be a bad pressure plate
Old Jan 6, 2006 | 09:45 AM
blueb18c's Avatar
hmm... do you have a stock gsr tranny?... the reason you might have problems going into gear not smooth might be the sycros are gone. check the pressure plate aswell.
Old Jan 6, 2006 | 09:49 AM
Eg6_rAcEr's Avatar
Default Re: transmisson problems!!!! please help!! (blueb18c)
well my tranny is stock and how would i check if i need new sycros or a pressuse plate
Old Jan 6, 2006 | 11:42 AM
tpr's Avatar
tpr
Check the movement of the slave cylinder at the transmission. Is it moving when you press the clutch in? if so how much? Is the slave or master cylinder leaking? The master cylinder will have fluid inside the car at the clutch pedal actuating rod. The slave will leak at the boot on the side of the transmission. Is there fluild in the system? Sounds like the clutch is not being fully released when the pedal is pushed down. If all that checks out then its time to pull the transmission and find out if its pressure plate, clutch disk.
Old Jan 7, 2006 | 02:41 PM
Eg6_rAcEr's Avatar
Default Re: transmisson problems!!!! please help!! (tpr)
will it make a difference if i am using a slave cylinder from my d15 motor on the gsr motor
Old Jan 7, 2006 | 02:54 PM
520_Motorsports's Avatar
when is the last time you replaced the clutch? If your master cylinder or slave is not leaking then you are probably running out of clutch material or the springs in the clutch disc are coming loose causing a binding!! Good luck!!
Old Jan 9, 2006 | 08:44 AM
pancake56's Avatar
Default Re: transmisson problems!!!! please help!! (SlowAzEg)
throw out bearing or pressure plate. your clutch assembly is not fully releasing the clutch disc from the flywheel. whirling noises are a result of a bad throwout bearing. my guess is the throw out bearing. If you have problems shifting to 4th then its a tranny problem.
Old Jan 10, 2006 | 09:50 AM
Eg6_rAcEr's Avatar
a nother problem is that the clutch pedel gets stuck when i release it. there is like a lag for it to come all the way up when it is released.
Old Jan 10, 2006 | 04:03 PM
Eg6_rAcEr's Avatar
bump still need help
Old Jan 11, 2006 | 12:18 PM
pancake56's Avatar
stuck pedal? slave cylinder.
Old Jan 11, 2006 | 04:53 PM
Eg6_rAcEr's Avatar
Default Re: transmisson problems!!!! please help!! (pancake56)
i fixed the pedal sticking. soo should i just replace the cluth then. since it might be the pressusre plate. the clutch plate. or the sycros. when i take my tranny apart how am i goin to know what is bad and not.
Old Jan 11, 2006 | 06:17 PM
Eg6_rAcEr's Avatar
up
Old Jan 11, 2006 | 06:47 PM
Honda Bull's Avatar
Clutch master cylinder or pressure plate would be my guesses.
Have you checked the clutch fluid yet? It's located at the driverside firewall in the smaller resevoir. It takes DOT3 brake fluid if you have some. But you haven't answered if you checked this yet.
I need to get around to doing my master cylinder here soon. My leaks like a.... well... .you know.
Old Jan 11, 2006 | 07:28 PM
Eg6_rAcEr's Avatar
Default Re: transmisson problems!!!! please help!! (Honda Bull)
yea i have checked the master cylinder already and i rebleed the system already. soo should i just buy a whoile new clutch
Old Jan 12, 2006 | 01:02 PM
Eg6_rAcEr's Avatar
i still need to kno if i should just buy a new clutch. soo any feed back would help
Old Jan 12, 2006 | 11:20 PM
Eg6_rAcEr's Avatar
up still need advice
Old Jan 12, 2006 | 11:31 PM
BOOSTED92EG's Avatar
cyncros are more than likely bad.... but the way it sounds about wanting to die while clutch is in... it sounds like u need to adjust ur clutch cuz the way it sounds its not disengaging... soo adjust ur clutch... but u might not have a bad cyncros cuz while shifting if u clutch is not disengaging than it will grinde or have to force in...
Old Jan 13, 2006 | 04:52 AM
Honda Bull's Avatar
Default Re: transmisson problems!!!! please help!! (BOOSTED92EG)
Not sure exactly how you adjust the clutch.... but more than likely... you'll find that it's adjusted all the way anyhow. Man, that would be a bitch to buy an all new clutch setup...
A friend with an ITR was having problem getting his into gear while pretty much sitting still. Once you got moving it would go in fine though. Turned out it ended up being his master cylinder, even though it wasn't leaking any.
If I were you, I'd probably hit up a junkyard for a clutch MC and replace it just to check it. They're probably $120 or so from Honda. Not sure. But I'm sure it wouldn't cost half that from a junkyard.
Old Jan 13, 2006 | 09:36 AM
Eg6_rAcEr's Avatar
how would i go about adjusting my clutch. If you could give me a step by step process i would appericate it. Also if my scyrnos are bad how do i go about fixing them.
Modified by Eg6_rAcEr at 11:25 AM 1/13/2006
Old Jan 14, 2006 | 04:28 PM
Eg6_rAcEr's Avatar
well i just changed my master cylinder and the problem is still there. the transmission is still acting the same way wanting to die. soo tommorw ima go and change ths slave clyinder and if that dosent work shold i just go and buy a new clutch?
Old Jan 15, 2006 | 10:23 PM
Eg6_rAcEr's Avatar
still need some help
Old Jan 16, 2006 | 08:17 AM
Honda Bull's Avatar
Still having problems even after the master cylinder, huh? That sucks. I highly doubt it will be the slave cylinder. But, not saying you can't try it if you feel the need.
I'm gonna say that possibly the pressure plate for the clutch is bad. Or maybe the bolts on the PP are even starting to back out.
Old Jan 17, 2006 | 10:16 AM
Eg6_rAcEr's Avatar
well i changed the slave cylinder and still the same problem. so then i am guessing it is the pressure plate. should i just change the pressure plate or shouold i go ahead and buy a whoole new clutch to be safe?
